For an irreversible sudden expansion from $V$ to $2V$, no heat is added during the expansion. However, the entropy changes by $N\log2$. I'm not sure how there can be a change in entropy without any heat added, since $dS = \frac{dQ}{T} = 0$. Of course, integration can yield $\Delta S = C$, where $C$ is a constant, but I'm not sure if this is the correct mathematical and physical way of thinking about this. Thank you for any and all help.
Asked
Active
Viewed 194 times
Your original equation is incorrect. The entropy change is not $\Delta S=\int{\frac{dq}{T}}$. The correct equation is$$\Delta S=\int{\frac{dq_{rev}}{T}}$$ where $dq_{rev}$ is the heat flow for an alternate reversible process between the same two end states. For such a reversible path, the heat flow will not be zero.
Chet Miller
- 35,124
