Measuring redshift is one of the ways of analyzing distance in astronomy, since the redshift of an object is caused by the expansion of space between us and the object, the more space there is between us, the more redshift it has.
My questions are
  • How do you measure the redshift individually?
  • Doesn't the movement of the galaxy relative to us cause an initial Doppler effect, adding an initial redshift in the light it emits?
  • How do you isolate what space does to the light from the total change?
  • And since the only way we can observe the object is with the redshift included, i.e. since we can't directly observe its original 'color', what do you compare the observed light to when calculating the redshift?
Stratiev
  • 1,799
The light we receive from astronomical objects doesn't have a uniform spectral decomposition. It contains many features such as emission and absorption lines, which correspond to specific frequencies of radiation that atoms interact with. These lines make distinct patterns, and we can recognize the patterns even when they're shifted by some frequency. That's how we can tell what the original wavelength is supposed to be: we compare the patterns we see to ones we find from nearby astronomical objects (e.g. the Sun) or from lab experiments.
Wikipedia has a nice illustration of this:
Two spectra, one with a pattern of lines on it and the other with the same pattern shifted, with arrows pointing from each original line to its shifted counterpart
David Z
  • 77,804
Do you mean "individually" for each star? (Or, for more distant object, for each galaxy?) If so then you do it by using a telescope to focus the light from that star, and that star only, onto a spectroscopic instrument such as diffraction grating (well actually they are a bit cleverer than that and deal with many stars at once by using CCD array detectors, but this is the principle).
Yes. Exactly right.
Two answers here. On the deeper level, the answer is you do not. Redshift is neither a purely velocity effect nor a purely spatial effect but a spacetime effect. But in practice we take note of a striking property of the universe: its uniformity on the largest scales. This means that the average behaviour, after averaging over groups of galaxies, is the same no matter where you look. So we divide the redshift from any given source into the part that agrees with the local average, and the part that stands out from the average. The first part describes cosmological expansion; the second part describes what are called "peculiar velocities" which refers to the difference form the average.
There are details, but the basic idea is that various properties of the source give strong hints as to what sort of source it is. For example, for stars one can find sets of absorption lines. These come in recognisable patterns reflecting the atomic elements in the outer layers of the star. In a musical analogy, it is like recognizing the different sound of a violin from a clarinet. Similar, one group of lines says "I am iron", another says "I am helium". But the groups are shifted away, as a group, from their values on Earth, all by the same frequency ratio. So we have a very strong evidence that the effect is a redshift. For observations of other things such as galaxies and supernovae there are other clues in the received spectrum.
Andrew Steane
  • 65,285
