Vacuum is said to have an intrinsic impedance. What is the source of this? Impedance is quite understandable in bulk matter, but I'm unable to comprehend it's presence in vacuum.
dsvthampi
  • 941
Impedance is a response of material to excitation. E.g., if we define an impedance of a conductor as a ratio of the applied bias to the resulting current, $$Z(\omega) =\frac{V(\omega)}{I(\omega)},$$ then nothing prevents us from defining it in the same way for vacuum. Naturally one would expect this impedance to be something simple like 1 (electromagnetic field passes without attenuation) or 0 (no electric current).
Specifically, one talking about the impedance of free space one often talks about the propagation of electromagnetic field $$Z = \frac{E}{H} = \sqrt{\frac{\mu_0}{\epsilon_0}},$$ which has dimensionality of resistance. The fact that in SI system of units this ratio is not $1$ is one of the main arguments against using this system of units in physics.
Roger V.
  • 68,984
