Short answer: it depends.
Edit: while I still disagree with Rob Jeffries on the conclusion, it's true that the main focus on your question shouldn't be on
Shall we ever stop receiving these CMB photons here on earth?
but indeed on
If this moment can be compared with the switching on of a cosmic lamp
because it shows a fundamental misconception. The answer to the "cosmic lamp" is, indeed, no, you can't compare it to a lamp, and the misconception is fundamental because it doesn't rely on expansion nor finiteness of the universe.
Try to think about it this way: the CMB happened everywhere at once. Neglecting the fact that it wasn't instantaneous, in the precise moment of the CMB you would have seen it from directly under your feet. A fraction of a second later, you would have seen it coming from a few meters away, and the reason for this isn't that in that point of the universe the CMB happened later: it's only because of the finite speed of light that we see it with this delay. If you keep this going, you'll arrive at 380000 years after those moments, and therefore receiving the CMB light from a very distant point. Now we're ready to answer the other question.
It depends on a high number of factors. It the universe is finite, then yes, you will see "the last CMB photon". If the universe is instead infinite, expansion becomes important: this answer by pela explains it very well.
