Why potential difference across no resistance wire is same across two points.
Asked
Active
Viewed 134 times
-2
Potential difference between point A and point B : Work done by the electric field in moving the charge from A to B.
If two points are separated by a resistance-less conductor, Then the electric field inside the conductor is zero.Thus,The charges experience zero electric force, and thus No work is done in moving the charges, and hence there is no potential difference.
satan 29
- 1,345
