I read that the meniscus, due to surface tension, exerts an upward pull to the liquid column below it. The water rises to a height until the weight balances the pull.
Now liquid exerts pressure because of its weight. Then why does the pressure in the liquid column increase with depth?
Vishnu
  • 5,336
Normally, for a small volume of liquid, the equilibrium of forces result in: $$\sigma_b \Delta x \Delta y - \sigma_t \Delta x \Delta y = (\Delta m) g $$ where $\sigma_b$ is the normal stress below and $\sigma_t$ the normal stress from top. Dividing by the volume $\Delta x \Delta y \Delta h$: $$\frac{\Delta \sigma}{\Delta h} = -\rho g $$
When delta tends to zero: $$\frac{\partial \sigma}{\partial h} = -\rho g $$
Integrating from $0$ (surface) to $h$ and considering that for a compression stress $\sigma = -p$: $$p = \rho gh$$
It is only valid because there are no shear stresses in the volume element, as it is usual for a solid material for example. In the capillarity tube, the shear stresses can not be disregarded, and $p = \rho gh$ doesn't apply.
What we can say is that at the surface of the container where the tube is located, and at the top of the tube, the pressure is atmospheric. So the column in the tube is compressed by the atmospheric pressure. Any small element of liquid in the tube is compressed, and has shear stresses. But it is not clear for me how to quantify all that stresses as a function of $h$.
