I am thinking the $z$ boson would remain with the combined mass of both the $Z$ boson and the Higgs boson. This is because the Higgs boson is a spin-0 boson and the $Z$ boson is a spin-1 boson.
The Standard Model allows two possibilities: The $Z$ can absorb the Higgs, or they can scatter off each other. The first corresponds to a three-particle $HZZ$ vertex in a Feynman diagram and the second to a four-particle $HHZZ$ vertex. You can see these two possible vertices in the answer to this question.
- 52,489
You seem to believe particles absorb/trade masses in reactions. They only trade energy and momentum.
For a real Z absorbing a real h to end up with a real Z, you'd need both energy and momentum to balance across the reaction. In the center-of momentum frame of the input particles Z and H you'd then have a total energy $$ E=\sqrt{m_Z^2 + p^2} + \sqrt{m_h^2 + p^2}, $$ and zero total momentum, by frame choice. The output Z would then be at rest, with total energy $E=m_Z$.
However, for absolutely any p, including 0, $$ m_Z\neq \sqrt{m_Z^2 + p^2} + \sqrt{m_h^2 + p^2}, $$ so your reaction will not go.
- 67,623
