A block of mass $1~\rm kg$ is lying on a table. It is stationary because the gravitational force is balanced by the force from the table. But the body should have an acceleration $g$ and consequently its change in momentum should be non-zero. But how come the body is at rest? Are there other examples where a body is at rest but is accelerating?
The body on the table is not accelerating because, as you said, the force of the table counteracts the force of gravity. The confusion here is perhaps from the term "acceleration due to gravity" but that doesn't mean that it has to cause an acceleration (at least once a steady state is reached).
An accelerating object can be momentarily at rest. For example, if you throw a ball into the air straight up, at the top of its trajectory it will be at rest.
rghome
  • 2,183
To elaborate on @rghome answer let’s comparie the situation where a mass is “at rest” on a table versus another mass being “at rest” at the same height at the top of a purely vertical trajectory,
In physics a body is “at rest” to an observer when it is stationary (motionless) in the reference frame of the observer, that is when it’s velocity is zero. The mass on top of the table is at rest in the reference frame of an observer standing still on the floor next to the table. In the same frame let another object of the same mass be launched vertically upward from the floor next to the table so that the top of its trajectory happens to be at the exact same height as the mass on the table. At that instant both masses are at rest (have zero velocity) to the observer.
But at that instant the net force acting on the mass on the table is $F_{net}=-mg+N=0$ where $N$ is the upward normal force of the table. From Newton’s second law
$$a=\frac{F_{net}}{m}=0$$
The only force acting on the launched mass is the downward force of gravity
$$F_{net}=-mg$$
And it’s acceleration is
$$a=\frac{-mg}{m}=-g$$
Both masses are momentarily at rest but only one is accelerating.
So a body may or may not be accelerating when it is at rest. It depends on whether or not it experiences a net force.
Hope this helps
Bob D
  • 81,786
Consider the case of a mass attached to a simple Hooke's Law spring, resting in an equilibrium situation (horizontally, vertically, on an incline--it doesn't matter). Then, displace the mass from the equilibrium situation collinear with the spring, defining the $x$ direction, by the amount $A$ and release at t=0. The displacement from equilibrium will be described by $$x=A\cos\Omega t$$ where $\Omega$ will be the angular frequency, a constant dependent on the spring constant and the mass.
If you take time derivatives to find the velocity and the acceleration, you will find that when the velocity is zero, the acceleration will be a maximum.
Bill N
  • 15,522
The body on the table is at rest and not accelerating in the reference frame of the table. A person doing a bungee jump next to it will at some point be able to say the body is at rest and accelerating with g. Many more reference frames are possible, inertial and noninertial, each giving a different answer.
my2cts
  • 27,443
