-2
I have read this question:
Is the force of gravity always directed towards the center of mass?
And G. Smith's answer lists a site where they specifically talk about this case mathematically.
https://possiblywrong.wordpress.com/2011/09/09/if-the-earth-were-a-cube/
At the center of each cube face, the force of gravity is almost exactly 1 g; at each corner, however, it is just 0.646 g, meaning that a person weighing 200 lbs. here on Earth would weigh only 129 lbs. A slightly weirder effect is that, standing on the flat surface of a cube-shaped planet, the force of gravity is not always “down.” That is, as you walk in a straight line from the center of a face toward a corner, gravity causes the flat face of the cube to seem to get steeper and steeper, so that you are eventually climbing instead of walking.
https://gizmodo.com/how-gravity-would-be-different-if-the-world-were-a-cube-1492018223
And this is very strange feeling you are like on the moon, much lighter, you could jump really high (but not fly away contrary to popular belief), and in some parts of the cube surface, and walking from the center to the corner you feel like climbing, meaning I believe that you could feel like rolling back to the center.
On Earth, an average jump can go 0.5 metre high, for 1 second. On the Moon, it is 3 metres and 4 seconds.
https://www.sciencealert.com/here-s-how-high-you-could-jump-on-other-worlds-in-the-solar-system
Question:
  1. How high can you jump (at the corner) on Cube-Earth (and are the corners really like steep hills)?
You can't fly away if you jump too high on the Moon in the first place. The Moon's escape velocity is 2380 m/s.
Besides that, the Moon's surface gravity is only 1/6 that of Earth, or in other words roughly $0.167g$. The minimum gravity on cube Earth is $0.646g$, about four times stronger than the Moon's gravity.
