In the book "Photonic Crystals, Molding the Flow of Light", the authors mention:
"Snell's laws are simply the combination of two conservation laws that follow from symmetry: conservation of frequency $w$ (from the linearity and time invariance of Maxwell's equations) and conservation of the component k$_{||}$ of k that is parallel to the interface.( from the continuous translational symmetry along the interface)"
I understand how the translational invariance leads to a conservation of k$_{||}$ in the medium on either side of the interface separately, but why should k$_{||1}$ be equal to k$_{||2}$ i.e k$_{||}$ remain conserved across the interface?
Snell's Law and momentum conservation
This thread provides answers with a classical intuition of billiard ball reflection, but I want to (1) understand how to use symmetries, and why, given that the two mediums are separately invariant under continuous translation, should the k$_{||}$ remain unchanged and (2) how do Maxwell's equations imply conservation of frequency
The main theorem connecting symmetry and conservation laws is Noether's theorem. Generally, it states that a quantity of $\left(\frac{\partial L}{\partial \dot{\mathbf{q}}} \cdot \dot{\mathbf{q}} - L \right) T_r - \frac{\partial L}{\partial \dot{\mathbf{q}}} \cdot \mathbf{Q}_r$ is conserved under perturbations in time and generalized coordinates $\mathbf{q}$ ($t \rightarrow t^{\prime} = t + \delta t, \mathbf{q} \rightarrow \mathbf{q}^{\prime} = \mathbf{q} + \delta \mathbf{q} ~)$. The Langrangian $L$ should be conserved (symmetric). $T_r, Q_r$ are some functions describing the perturbations: $$\delta t = \sum_r \varepsilon_r T_r $$ $$\delta \mathbf{q} = \sum_r \varepsilon_r \mathbf{Q}_r ~$$
As for me, this is not something you can understand intuitively since the perturbations could have a very complicated form. However, we can consider two easy cases:
1) $T=1, r=1, Q=0$, so simple linear translation in time. Then the Noether's quantity reads: $$\frac{\partial L}{\partial \dot{\mathbf{q}}} \cdot \dot{\mathbf{q}} - L$$. This is basically formula of hamiltonian, i.e. total energy of a system.
2) $T=0, r=1, Q=1$, so simple linear translation in a space coordinate. Then the Noether's quantity reads: $\frac{\partial L}{\partial \dot{q_k}}$, which is a momentum.
Now, talking about light, we should remember wave-particle duality and consider photons with momentum and energy. Momentum is wavevector $k$ and energy $\hbar \omega$. Linear translation in time and space for a photon just means a phase shift that couldn't affect a Lagrangian so it is conserved. Consequently, we have corresponding wavevector and frequency conservation laws.
