We know the Maxwell action can be written as the tensor product of the tensor $F^{ab}$ with itself. $F^{ab}F_{ab}$
[Edit: This bit I forgot to mention in the original quesiton] Using the product rule one can write the action $\int\sqrt{-g}Rdx^4$ in terms of first derivatives only (ignoring boundary terms). Call this Lagarangian $B$. So:
$$B=\sqrt{-g}\left( g^{ab}g^{de}g^{cf} +2 g^{ac}g^{bf}g^{de} + 3g^{ad}g^{be}g^{cf} -6 g^{ad}g^{bf}g^{ce} \right)\partial_c g_{ab}\partial_f g_{de}$$
Simimlarly is there a tensor (or indeed a non-tensor matrix object) $P^{abc}$ such that $P^{abc}P_{abc}=B$? $P$ should contain only first derivatives of $g$. i.e. ignoring boundary terms: $\int \sqrt{-g}R dx^4 = \int\sqrt{-g}P^{abc}P_{abc}dx^4$
Or is there a simple proof that this is not possible?
My guess is you would write:
$$P_{abc} = \alpha_1 \partial_a g_{bc} + \alpha_2 \partial_b g_{ac} + \alpha_3 \partial_c g_{ab} + \alpha_4 g_{ab} g^{ef}\partial_c g_{ef} + \alpha_5 g_{ac} g^{ef}\partial_b g_{ef}+ \alpha_6 g_{bc} g^{ef}\partial_a g_{ef}$$
And see what values of $\alpha$ would possibly solve it. Even if the $\alpha$ are non-commutative.
Edit: Using computer software I think it can be done where the $\alpha$ are complex numbers. Don't think there is a real valued solution.
Though not precisely what you intended, you might be interested in MacDowell–Mansouri formulation of gravity.
This formalism combines the Levi-Civita connection and coframe field into a single physical field, leading to a gauge theory Lagrangian: $$S_\text{MM}[A]=-\frac{1}{2\Lambda} \int \mathrm{tr}\,(\hat{F}\wedge \star \hat{F}),$$ with either de Sitter or anti-de Sitter group as the gauge group (depending on the sign of cosmological constant).
This action is classically equivalent to Einstein–Hilbert action with cosmological constant (the difference between these actions is proportional to purely topological Gauss–Bonnet term that does not change the EFE's).
The original paper:
  • MacDowell, S. W. & Mansouri, F. (1977). Unified geometric theory of gravity and supergravity. Phys. Rev. Lett. 38 (14): 739–742. doi:10.1103/PhysRevLett.38.739.
More accessible exposition could be found in thesis by D. Wise, see also his paper or these slides.
A.V.S.
  • 17,324
