Not all of the heat input to a gas is absorbed if it is over a finite temperature difference and thus not reversible.
If we have say, a isochoric irreversible process, so no work can be done either, where does the heat that isn’t absorbed go?
Alex Gower
  • 2,684
That's not true. If you add some amount of heat $Q$ to a gas and don't allow it to perform any work, then the internal energy of the gas will increase by $Q$ whether the process is reversible or not.
The difference between a reversible process and an irreversible process is that in the latter case, the entropy of the universe increases. If the heat is transferred over a finite temperature difference, the entropy of the gas changes by
$$\Delta S_{gas} = \int \frac{\delta Q}{T_{gas}} = \int_{t_0}^{t_f} \frac{\dot Q}{T_{gas}(t)} dt$$
where $\dot Q$ is the rate at which heat is transferred to the gas and $T_{gas}$ is the temperature of the gas at time $t$, while the entropy of the environment changes by $$\Delta S_{env} = \int \frac{-\delta Q}{T_{env}} = \int_{t_0}^{t_f} \frac{-\dot Q}{T_{env}(t)} dt$$
The net change in entropy of the universe is therefore
$$\Delta S = \Delta S_{gas} + \Delta S_{env} = \int_{t_0}^{t_f} \dot Q \left(\frac{1}{T_{gas}} - \frac{1}{T_{env}}\right) dt$$
If the environment is at a higher temperature than the gas, then $\dot Q>0$ and $\frac{1}{T_{gas}}-\frac{1}{T_{env}} > 0$ the whole time, which means the integral is strictly positive and the entropy of the universe increases.
It can’t be absorbed right otherwise it would be the same result as a reversible process.
If you transfer some amount of heat $Q$ to a gas which is not permitted to do any work, then the increase in entropy of the gas is the same whether the process is reversible or not. It is the entropy change of the system plus its environment which depends on the irreversibility of the transfer.
Albatross
  • 72,909
