15
I noticed that pouring tea from a cup to a plate leads to a horizontal jet of the fluid.
( You can click on the image to see video)
The jets were linear and extended to both the directions from its point of contact with the fluid. The speed of flow in these jets was higher than that of the radial flow*. I could reproduce the effect better using water.
  • Why do these jets form? Why doesn't the fluid just flow radially?
I know that freely falling fluids have shape oscillations, which causes the periodic elongation of its cross-section.
I noticed that these jets (red lines) were always orthogonal to this direction of elongation (green lines) at their point of contact. Naturally, I would expect this direction to be parallel to that of the elongation. The following video illustrates this well.
  • Why does the jet flow orthogonally to the plane of elongation?
*For a perfectly cylindrical stream, the cavity is circular.
Since an elongated cylinder is like two closely placed cylinders, shouldn't the cavities be a combination of the two circles, i.e an elongated circle? In fact, it does turn out to be an elongated circle, but the elongation is in the wrong direction.
This suggests that jet velocity is higher than the radial flow velocity.
AlphaLife
  • 13,439
I think the elongation is caused because some of fluid (at the top) flows freely from the cup, whereas some is subject to viscous drag from the cup when pouring, and thus has lower horizontal velocity as it leaves the cup.
When the fluid hits the plate, fluid tends to flow away at right angles from the surface of the downward flow --- a perfectly cylindrical downward flow would produce a radial flow outwards from the point it hits the plate. Two such cylindrical flows next to each other would each prevent radial flow in the direction of the other. This would redirect fluid from both so that it goes perpendicular to the line between the flows.
That's easy. Notice that the jets form between the two large vertical "pipelines" that feed the intersection with the plate. Both pipeline columns create a high stagnation pressure where they contact the plate and that pressure accelerates flow along the plate in a laminar film, outward from the foot of the pipeline. Surface tension keeps the laminar flow area thin in the vertical direction. The laminar flow of both columns intersect however, causing a further, but slight increase of (dynamic) pressure, pushing the laminar flow in at that intersection both a little upward and outward in the geometry that looks like a jet. The jet flow is confined to itself because as it moves along, the intersection line of the two laminar spreading flows keeps feeding it. Turbulence eventually dominates and the more ordered flow gets broken up.
ttonon
  • 287
For a perfectly symmetric stream, you have a white hole horizon.
I quote Ulf Leonhardt's book Essential Quantum Optics, p.210: "Inside a certain ring the water surface is very smooth, but outside waves are appearing. Where the stream from the tap hits the metal, the water flows faster than the wave velocity. Then the water flows outwards and gets slower. Waves can not enter the region where the water exceeds their velocity, but they are formed at the critical radius where the water has reached the wave velocity (...) Seen from an astrophysics perspective, this resembles a white hole, an object that nothing can enter."
You can read also https://arxiv.org/abs/1010.1701.
Other regimes are shown in http://math.mit.edu/~bush/?p=843
I guess that the asymmetry of the stream from the tap breaks this balance, and the waves (the jets) appear by the side the water from the tap is flowing at the wave velocity (or very close) when hitting the metal.
Urb
  • 2,724
Daniel
  • 41
