My professor wanted me to master these topics from Fourier Analysis. I need a resource where these topics are discussed in brief. Although i know many of the topics in the list, i prefer a good resource to brush up my rusty knowledge and learn what i don't know. The topics are:
  • Fourier series: sin and cos as a basis set; calculating coefficients; complex basis; convergence, Gibbs phenomenon
  • Fourier transform: limiting process; uncertainty principle; application to Fraunhofer diffraction
  • Dirac delta function: Sifting property; Fourier representation
  • Convolution; Correlations; Parseval's theorem; power spectrum
  • Sampling; Nyquist theorem; data compression
  • Solving Ordinary Differential Equations with Fourier methods; driven damped oscillators
  • Green's functions for 2nd order ODEs; comparison with Fourier methods
  • Partial Differential Equations: wave equation; diffusion equation; Fourier solution
  • Partial Differential Equations: solution by separation of variables
  • PDEs and curvilinear coordinates; Bessel functions; Sturm-Liouville theory: complete basis set of functions
  1. If your into solving a lot of examples and gathering some intuition i recommend Schaum's outline series. They have nice solved examples. (https://www.amazon.com/Schaums-Analysis-Applications-Boundary-Problems/dp/0070602190)
  2. If you are into more technical mathematical stuff, here is a textbook I used. (https://www.amazon.com/Introduction-Fourier-Analysis-Russell-Herman/dp/1498773702)
  3. A great way to learn about DFTs and Signal Processing in general, I recommend going through some coding problems and in such case, technical notes from NI and some coding textbooks helped a lot. (https://www.ni.com/ko-kr/innovations/white-papers/06/using-fast-fourier-transforms-and-power-spectra-in-labview.html)
