The definition of drift velocity "the average velocity with which the free electrons in a conductor gets drifted towards the positive end of the conductor under the influence of an electric field applied across the conductor"
Then comes mobility where they say "mobility of free electrons is independent of electric field" Doesn't this contradict the the motion of free electrons in an conventional current which is due to applied electric field in specific situation
You are right in saying that motion of electrons is due to applied field. This motion is drift velocity. From your own statement we have,
$$v_{d}\ \propto \ E$$
introducing a constant: $$v_{d}\ =\ μE$$
where μ is the mobility, which, obviously does not depend on E
Mobility is an intrinsic property of a conductor, which gives behaviour of electrons (i.e. speed) when electric field is applied.
Elendil
  • 1,385
Qualitatively, think of the overall motion of electrons as having two components.
One component involves the mobility of free electrons. That is the very rapid random motion of the individual electrons in a conductor due to thermal energy, for which there is no net collective motion of the electrons in any particular direction. This random motion is related to the mobility, μ, in Krishna's answer.
The second component occurs when an electric field is introduced. The electrons now collectively move toward the direction of the "positive end of the conductor" as you put it. Or, more formally, the electrons collectively move in a direction opposite to the direction of the electric field in the conductor. By convention, the direction of the electric field is the direction of the force (and movement) that a positive charge would experience if placed in the field.
The collective motion of the electrons is called the drift velocity and is directly related to the current in the conductor. This velocity is very slow compared to the random velocities of the electrons that occur with or without the electric field present.
No it doesn't. Because drift velocity, the motion of the electrons collectively which is very slow, is independent of the mobility, which is the random velocities of the individual electrons. Let me give you rough analogy.
Suppose you are on the shore and able to see a school of fish where the individual fishes are freely and rapidly darting about in no particular direction. That's roughly analogous to the mobility. But then you also see the whole school moving slowly from left to right because of the ocean current moving in that direction. That would be their collective drift velocity.
Hope this helps.
Bob D
  • 81,786
The answer by @Elendil is correct. I would like however to add that the property that mobility is independent on electric field is known as Ohm's law - which is readily obtained by transforming drift velocity to current and electric field to potential.
It is also worth adding that Ohm's law is not a real law of nature, but an empirical law, which applies in many commonplace situations, but is really just an approximation - see this answer for more details.
Roger V.
  • 68,984
