General solutions to the wave equation in $\mathbb R^3$,
$\partial_{tt}\phi(t, \mathbf r) = c^2\Delta \phi(t,\mathbf r)$
can be obtained by first splitting off the time component, e.g. with a Fourier transform or separation of variables, leading to the Helmholtz equation $(\Delta+k^2)\psi(\mathbf r)=0$. General solutions to the Helmholtz equation can then be found in various coordinate systems:
  • Cartesian coordinates lead to a superposition of exponential functions ("plane-wave expansion"),
  • spherical coordinates lead to to spherical harmonics (multipole expansion),
  • cylinder coordinates lead to Bessel functions, etc.
I'm wondering whether there is a coordinate-free general solution.
A coordinate-free "wave equation" is
$(d^\star d+dd^\star) \alpha = 0$
(see, for example, Frankel, The Geometry of Physics ed 1, Ch. 14). $\alpha$ is a one-form in Minkowski space, $d$ is the exterior derivative ("differential"), and $d^\star$ is the co-differential.
The existence of such a coordinate-free expansions would imply that the exponential, spherical harmonics, Bessel functions, etc., are related by simple coordinate transformations, which they are not. So the answer must be no. Or am I missing something?
mcmayer
  • 201
In fancy "coordinate-free" language, the solutions to the wave equation $(d^* d + d d^*) \phi = 0$ are called harmonic $0$-forms. Hodge's theorem states that for certain compact manifolds, harmonic forms are in correspondence with cohomology classes. Thus for $0$-forms the statement is that the number of independent harmonic functions is the number of connected components of your manifold, since the harmonic forms are just constant on each component.
Unfortunately, this theorem doesn't apply to $\mathbb{R}^3$, as it isn't compact.
Of course they're related, these just represent different bases for the same space of solutions. (Specifically, the basis that is useful in each corresponding coordinate system.) For example, taking the Fourier transform of a Bessel solution manifestly writes it in terms of exponentials. The standard plane wave expansion does precisely the reverse.
In the fancy language, you don't need to think about this... but there's also not much you can say.
knzhou
  • 107,105
