I'm so confused. I've read in this book (page 28) that group velocity of light can exceed $c$ in certain gases. However a lot of people online and in the forums say that phase velocity can exceed $c$.
Who's right? According to that same book, group velocity is not signal velocity and it's signal velocity which cannot exceed $c$ without violating causality. So is everyone correct? Do both phase and group velocity change when entering a new material, and can they both exceed $c$?
I would really appreciate any help clearing things up here.
Quote from the book:
In a spectral region of ‘normal dispersion’, $(\mathrm d n_R/\mathrm d\omega)_{\omega_L} > 0$, the group velocity is less than the phase velocity $c/n_R$. Because $v_g$ can exceed $c$ in a region of anomalous dispersion, $(\mathrm dn_R/\mathrm d\omega)_{\omega_L} < 0$ (section 1.2), and because $v_g$ was generally thought to be the velocity of energy propagation, $v_g > c$ was, in the past, thought to be in conflict with the special theory of relativity. This conflict was resolved in large part when Sommerfeld and Brillouin proved that the signal velocity cannot exceed c even in a region of anomalous dispersion.
Info in case the link breaks in the future.
Title: Fast Light, Slow Light and Left-Handed Light
Author: P W Milonni
Published by: Institute of Physics Publishing, 2005
Wavefronts and phase velocity faster than $c$
Ruslan
  • 30,001
  • 70
  • 154
Alex P.
  • 143
Yes, phase velocity can and does exceed c. This is not a contradiction with SR.
So when phase is treated correctly, it doesn't affect any observable. That's why SR doesn't care about phase velocity.
Wave group and phase velocities
However, group velocity should not exceed c except in certain cases, but even then, this does not mean information traveling faster then light.
In all these cases, however, there is no possibility that signals could be carried faster than the speed of light in vacuum, since the high value of vg does not help to speed up the true motion of the sharp wavefront that would occur at the start of any real signal. Essentially the seemingly superluminal transmission is an artifact of the narrow band approximation used above to define group velocity and happens because of resonance phenomena in the intervening medium.
https://en.wikipedia.org/wiki/Group_velocity
