Isn't Air resistance very similiar to friction? So why is air resistance an exception that depends on contact area compared to other frictional forces?
Zheer
  • 512
Because the fact that a portion of the area is deflecting air and thus feeling drag does not prevent (on average) other air around it to be deflected by neighbouring areas, thus increasing the total drag on the object.
For friction, however, since it is proportional to the normal weight, and since the total weight is held constant (I assume), the fact that some portion of area is feeling the weight means that it is holding part of the shared weight, removing part of the weight from their neighbours, thus decreasing the friction force per unit area.
In a word, in the first case more area displaces more air, while in the second more area sustains the same weight.
The link that @Charlie provided ( physics.stackexchange.com/q/154443 )already provides the details of the reasons for the independence of dry contact friction on surface area. The following will rather elaborate on the difference between the mechanisms of air resistance and dry friction.
Both air resistance (a.k.a. air drag) and dry contact friction are dissipative forces. That is, they dissipate the macroscopic kinetic energy of the moving object(s) involved and convert into other forms (heat, light, etc.). However the mechanism by which the energy is dissipated differs as well as the dependency upon surface area as you already know.
In the case air resistance, the moving object has to "push" or compress the air in front of it while moving it out of the way. All other things being equal, the larger the projection of the surface area of the object in the direction of motion, the more air that has to be pushed away and therefore the greater the air resistance. The work the object needs to do to push the air results in a loss of macroscopic kinetic energy of the object. The main result in an increase in the local temperature of the air (an increase in its internal microscopic kinetic energy) sometimes, though technically erroneously, referred to as heat.
In the case of dry contact kinetic friction, the relative motion between the surfaces raises the temperature of those surfaces (increases the internal microscopic kinetic energy of the materials). The elevated temperatures then result in heat transfer to within the materials and to the environment.
Hope this helps..
Bob D
  • 81,786
