I understand that this question is asked many times on PSE, but my questions which I ask below are slightly different. I have read almost all the discussions on PSE on the topic but a few questions are still unanswered.
In the following post: Is there any potential associated with magnetism
Luboš Motl says the following:
The force qv×B acting on a charged particle is clearly not conservative because it depends on the velocity. Conservative forces are those that integrate to a fixed work – energy difference that is independent of the path – between two points so they may only depend on the location. We can't associate a potential with a force that is velocity-dependent.
My questions are the following.
- How Velocity-Dependence of a Force makes it Non-Conservative?
"We can't associate a potential with a force that is velocity-dependent."
Magnetic force doesn't do any work, so it's work in a closed-loop will also be zero, so this in a way seems to make magnetic force a conservative force. Why not, it is then a conservative force?
What about Magnetic Field? If there are no currents and there are no changing electric fields then also we can have magnetic fields due to Bar Magnets. Are the magnetic fields due to Bar Magnets Conservative?
This idea of Conservative or Non-Consverative has become quite confusing, given several examples, which do not seem to cohere with each other. Is there any single rule with the help of which we can distinguish between Conservative and Non-Conservative?
Kindly help.
