While getting familiar with relativity, the second postulate has me stuck. "The speed of light is constant for all observers". why can't light slow down for an observer travelling the same direction as the light?
It is actually better to work from the general principle of relativity, that
- Local laws of physics are the same irrespective of the reference matter which a particular observer uses to quantify them
which is an expression of Hume's Principle of uniformity in Nature,
- the fundamental behaviour of matter is always and everywhere the same.
Without this principle, there would be no science because if laws could change observing them would be meaningless.
It follows that all observers can set up coordinate systems in exactly the same way. There are then two possibilities. Either there is, or there is not, a maximum speed in nature. If there were not, the laws of physics would be different from those we observe (e.g. Newtonian relativity would hold for classical electrodynamics and numerous empirically confirmed predictions of relativity would have been false). Hence there is a maximum speed which is necessarily constant for all observers.
Relativity depends on this logical argument, not strictly on the physical speed of light. It just happens that, to the accuracy of measurement, the speed of light is equal to the maximum speed.
- 11,871
It does seem strange at first, it sounds like you're asking "If I'm moving towards a source of light won't I see the light travelling faster than c?". If you picture yourself standing still, watching someone drive past you on a car, if they throw a tennis ball in the direction they're driving the speed of the tennis ball will be whatever velocity they throw it at from their point of view PLUS the speed of the car from your point of view. If you repeated this experiment with a torch instead surely you would see the light travelling at $c$ PLUS the speed of the car? The actual answer is you would not, and in fact the tennis ball doesn't even travel at exactly the speed as outlined above. In special relativity everyone measures the speed of light to be the same value regardless of where they are.
You can show that length contraction and time dilation are two derived concepts from the second postulate.
- 7,159
We have no answer to the question why the speed of light is a constant for all observers. Physics describes the laws of nature and not why nature does it this way. Thus, this question is beyond the scope of physics.
- 9,818
- 1
- 15
- 32
The short answer is, because if we assume the speed of light is constant then our equations predict experimental outcomes with greater accuracy.
The electromagnetic answer is, because if you plug the measured permittivity and permeability of free space into Maxwell's equations, that is the speed you get.
The Relativistic answer is, the speed of light is assumed to be a law of physics, and therefore a constant for all observers.
- 7,578
It is the speed of causality. If there was no limit in how fast information can travel all would happen at once. The universe is a causal place because information needs time to travel a distance. Your question is probably much deeper than you intended it to be.
- 352
The constancy of speed of light was first predicted by Maxwell. He had discovered for equations, which we now call Maxwell equations.
Maxwell equations
$$\nabla\cdot{E}=\frac{\rho }{\epsilon_{o}}$$ $$\nabla\times{{E}}=-\frac{\partial B}{\partial t}$$ $$\nabla\cdot B=0$$ $$\nabla\times B=\mu_o j+\mu_o\epsilon_o \frac{\partial E}{\partial t}$$ These four equations represent the Maxwell equations. First let’s see what are the conditions/constraints of the vacuum equations. In a vacuum there is no charge, so ρ just becomes zero. Also the is no change in current in vacuum, which means $\frac{\partial j}{\partial t}$ will be zero
Electromagnetic Waves and Maxwell Equations
Integrating the second Maxwell equation with respect to time we get
$$ B=-\int{\nabla\times{ E}}{dt}$$
Now let's put this expression for B into the fourth equation. Note we are allowed to interchange the positions of the integral and curl in this case.
$$-\int\nabla\times{\nabla\times E}dt=\mu_o\epsilon_o\frac{\partial E}{\partial t}$$
Now this equation simplifies as
$$-\frac{\rho}{\epsilon_o}+\nabla^2 E=\mu_o\epsilon_o\frac{\partial^2 E}{\partial t^2}$$
Now as we have written the equations for vaccum, $\rho =0$ hence our equation just becomes
$$\nabla^2 E=\mu_o\epsilon_o\frac{\partial^2 E}{\partial t^2}$$
Now this equation is very similar to the standard wave equation which is
$$v^2\nabla^2 \phi = \frac{\partial^2 \phi}{\partial t^2}$$
Thus by comparison, we get
$$c=\frac{1}{\sqrt{\mu_o\epsilon_o}}$$
Alright but what does this have to do with the constancy of speed of light in vaccum?
The fact is that $\mu_o$ and $\epsilon_o$ are independent of reference frame, and hence, the speed of light in vaccum is a fundamental constant irrespective of the reference frame in question. This was the start of Theory of Relativity as proposed by Einstein.
Experimental Evidence
After the predictions, Michaelson and Morely performed the famous experiment which proved that the speed of light was to be independent of reference frame or else the Earth wouldn't be moving
- 1,880
- 6
- 21
Speed of light is constant in all inertial frames in a vacuum, this is a postulate of Special theory of Relativity. There was no assumption that Speed of light is the fastest traveling speed in the Universe but if you study Special theory of Relativity closely, you will understand that particles having zero mass can only have the highest speed, like approximate massless particles, neutrinos travel really fast but never reach the speed of light, because light particles are massless. Now, following from Maxwell's theory of Electromagnetism, you can understand that EM waves/fields are traveling with very fast (not yet the speed of light or photons or massless particles), you will observe that EM fields/waves don't change their speed when the reference frame is changed. This was the most important observation by Maxwell and Faraday knew this will revolutionize Physics which happened when Einstein took this as a postulate and then as people were working on experiments to find massless particles and they found that they already knew that these are EM waves or photons or LIGHT!
Physics also answers why such postulates are made.
Edit:- someone has downvoted this answer, either the person didn't read it or don't know the content. Would you tell why you downvoted the answer?
