The mystery of the mass of the top being in the electroweak scale can be justified by the Higgs mechanism itself; in some sense the top mass is the only "natural" mass, the other masses of fermions being protected by some unknown mechanism so that they are "zero" relative to the electroweak: the typical values of the Yukawas are in the $10^{-3}$ range and even smaller. The masses are still "natural" relative to GUT or Planck Scale cutoffs, because then their corrections are logarithmic and about the same order of magnitude that the mass itself, in fact about a 30%.
My question is about the mass of tau and mu. Is there some reason for them to be in the GeV range, where QCD masses -proton and pion, if you wish, or glue and chiral scales- are?
I am asking for theories justifying this. For instance, Alejandro Cabo tries to produce first the quark masses from the one of the top quark via QCD, very much as Georgi-Glashow electron-muon in the early seventies, and then he expects that the leptons should have masses similar to the quarks via the electromagnetic/electroweak coupling (albeit some group theoretical reason could be enough).
Hierarchically, and from the point of view that any near zero value for a coupling is a hint for a broken symmetry (so that in the limit where this symmetry is unbroken, the coupling is exactly zero), what I would expect is a symmetry protecting all the yukawas except the top, and then still a subgroup protecting the first generation.
299792458
  • 3,214
arivero
  • 1,901
The anthropic principle might explain it.
  • The difference in mass of the neutron and proton is roughly the difference in mass between that of the down and up quarks, which is comparable to that of the electron mass. If the proton were significantly heavier, they would decay into neutrons — which are electrically neutral — leading to no atoms or chemistry.
  • The instability of neutrons with a half life of 15 minutes is necessary, as otherwise, most of the hydrogen and neutrons would fuse together into deuterium during the big bang nucleosynthesis epoch. This means the mass of the neutron should be slightly larger than the sum of proton and electron masses.
  • For chemistry as we know it to be possible, molecules ought to have definite shapes, as opposed to a delocalized quantum superposition of nuclei positions. This requires the nucleons to be at least 1000 times heavier than the electron, fixing the QCD scale.
  • The weakness of the weak interaction is due to the smallness of the Yukawa couplings for the first generation of fermions. If the weak interaction were significantly stronger than it is in our universe, the neutrinos generated during the explosive fusion when the core of a massive star collapses will interact too strongly with the stellar matter that they would be absorbed before reaching the outer regions of the star. In our universe, the weak interaction is sufficiently weak that enough neutrinos can reach the outer regions, but yet strong enough to interact sufficiently there to blow the outer region away in a supernova. Without supernovae, we won't have planets with significant quantities of heavier elements needed for life.
However, I can't think of any anthropic reason why the Yukawa coupling for the tau lepton isn't of order unity.
QGR
  • 2,377
