Referring to the famous example of a horizontally moving sticky ball that collides (and sticks) at the tip of a vertically floating rod, then the combination moves along the ball's incident course while rotating. For the above case, we assune that the final linear momentum is exactly the same as the ball's linear momentum, and even if the ball hits the rod at its center of mass we still apply the same conservation of linear momentum principle. However, if we look at the things from linear KE's perspective, then the first case implies a split of the ball's initial KE over the linear and rotatiinal KEs of the final combination, which means less final linear KE than the initial ball's KE, and the second case implies that the combination will have the same initial linear KE of the ball (since no rotation will occur).
My question is: How would the final combination in both cases have different linear KEs while having the same linear momentum (due the linear conservation)?
