According to special relativity (as I understand it) simultaneity is no longer a universal concept in special relativity. Consider two events A and B which are simultaneous in reference frame 1; in reference frame 2, A might precede B timewise; in reference frame 3, B might precede A.
Suppose in reference 2 we might consider scrambling an egg: event A, egg is dropped into the frying pan; event B, egg is cooked. It seems counter to common sense that there would be a reference frame in which the egg is cooked before being heated in the pan.
In other words, does entropy, $S$, "Time's Arrow," trump relativity?
duhem7
This is true, if the events happen at spatially separate locations in reference frame 1. In technical language, the events must have a "spacelike" separation between them.
(Moreover, we assume that the events are true 'pointlike' events, i.e., that they have zero duration. If not, then the spatial separation between the two, in reference frame 1, must be longer than $c$ times their duration, in order for this property to hold.)
Your example (scrambling an egg) necessarily happens in the same location in a given reference frame (that of the egg) with a nonzero time between the start and the end, which means that it has a "timelike" separation between events. That means that those two events will never appear simultaneous, or in reversed order, in any other reference frame.
In other words,
No.
Emilio Pisanty
  • 137,480
These events must be "spacelike". They are separated in space by a sufficient degree that light cannot start from one event and reach the other. Yes we can find reference frames where one event precedes the other, but in none of the frames can light start at one event and reach the other.
These events are not spacelike, but "timelike". It is possible for light (or in some cases, slower objects) to travel from event A (the time and place where the egg is scrambled) to event B (the time and place where the egg is cooked). Because these events are close enough to each other in space, but not time, there are no reference frames in which they are simultaneous. Another way of saying this is that the timewise ordering of the events is consistent in all reference frames (A always precedes B).
The ambiguous ordering of events is only true for certain sets of events, not all. If you take a look at a light cone diagram, you will see that for a cone centered at the breaking of the egg, the event of scrambling that egg lies in that event's future. Only events in the "elsewhere" outside of the cone can be considered simultaneous in some reference frame.
Changing reference frames can shift events around inside the cone and outside the cone, but can never move an event across the cone's boundary. Future events remain in the future in all frames.
BowlOfRed
  • 42,997
  • 68
  • 123
I don't think this is possible. Just because simultaneity is no longer universal in special relativity does not mean that you can find a frame in which causality is violated.
Your situation is a bit tricky, because in order for the pan to heat the eggs, it needs to be (roughly) at the same position. But if two events take place at the same place and time in a reference frame, they will also take place at the same place and time in any reference frame.
In order to see the situation a bit more clearly, imagine now that $A$ is an atomic bomb exploding at $t = 0$ and $x= 0$, and suppose that the radiation from the explosion (propagating at $c$, i.e the speed of light) is enough to cook instantly an egg at $x = L$. In the reference frame $R$ where both are at rest, this event takes place at a time $t=L/c$ (more generally $t=L/v$ where $v \leq c$), which is the time needed for the energy to propagate from the explosion site to the egg.
We say that the separation between $A \, (t=0, x=0)$ and $B \, (t=L/v, x=L)$ is timelike (or lightlike if $v=c$) in $R$, because one event, $A$, can be the cause of the other, $B$.
You can show that in special relativity, a timelike (resp. lightlike) interval remains timelike (resp. lightlike) in any frame of reference, with the order of causality unchanged.
If we boost to a reference frame $R'$ moving at $V$ with respect to $R$, $A$ will be unchanged in the new coordinates $(t'=0, x'=0)$, while $B$ can be written as $B(t' = \gamma (t - Vx/c^2), x' = \gamma(x - Vt))= B(t' = \gamma L/v(1-vV/c^2) > 0, x' = \gamma L (1 - V/v))$. You can see immediately that $t' > 0$ (meaning that $B$ happens after $A$ in any reference frame), and, with a bit more calculations, that $c t' \geq x'$ (meaning that the signal of the explosion is able to propagate from $A$ to $B$ in the time $t'$ between the two events.
QuantumApple
  • 1,757
