Now suppose a magnetic field is increasing inwards and we keep a loop of radius $r_B$ as shown in the picture below.
$\oint\mathbf E\cdot \text d\mathbf l= \text d\phi/\text dt$, which means $E(2\pi r_B)=(\pi(r_B)²)*(\text dB/\text dt)$(as the electric field is uniform in magnitude around the loop).
The magnitude of the electric field induced should be uniform because of symmetry, as according to my textbook (without any much said reason)
$$\text{For } r<R, E_n(2\pi r)=\pi r^2\,\left|\frac{\text dB}{\text dt}\right|\to E_n=\frac r2\cdot\left|\frac{\text dB}{\text dt}\right|$$
Which means the Electric field at point A is given $E_A=(r_B/2)*(\text dB/\text dt)$
Now if I keep a small loop of radius $r_s$ such that $r_s<r_B$ as shown in the below figure.
Note small loop is kept after removing large loop means two loops are kept one after another.
Now again applying Maxwell’s equation around loop $\oint\mathbf E\cdot\text d\mathbf l=\text d\phi/\text dt$ and using same method as above we get electric field at A as $E_A=(r_s/2)*(dB/dt)$. Why does the electric field induced depend on loop kept in the field?
From my intuition, I think the electric field at a point induced should be independent of size of loop. So, from the earlier shown equation we see that $$ \frac{r_s}{2}\cdot\frac{\text dB}{\text dt}=\frac{r_B}{2}\cdot\frac{\text dB}{\text dt}$$
so $$r_s=r_B$$ But this is a contradiction to our assumption that $r_s<r_B$.
Please consider explain where I am going wrong. Thank you in advance.
Please explain why and how loop choice affects exactly.Then give priority to explain from mathematical equation.
