A beam of light of wavelength $\lambda$ and width $W$ needs to be focused at a distance $D$ to a spot not bigger than $w_S$, which stands for 'width of sail'.
Now, the diffraction limit says it clearly that a coherent beam will diverge at a rate no less than $\frac{\lambda}{W}$, and that the minimal target spot width will be $\sqrt{D \lambda}$. But my understanding from the comments in this question is that this applies in the far-field limit far away from the focal point, so my doubt is that if this hard bound on the spot size can be avoided by replacing the collimated beam by a focusing beam with an extremely long focal length.
So, my question boils down to the following: can the fundamental diffraction limit on spot size, be replaced with the extremely difficult, but possible in principle engineering problem of creating a focusing element with extremely high focal lengths, in such a way that for a specific length, the target spot size can be made smaller
A concrete scenario to make things more clear: the wavelength is $\lambda = 10^{-6}$ meters. The distance to the target is $D = 10^{12}$ meters ($10^{18}$ wavelengths). If the beam converges at focal length $D$, my hope is to keep the beam spot (which in this case coincides with the beam waist) at $10^2$ meters (which is 10 times smaller than the target beam spot if the laser would have been collimated, instead of focusing at $D$)
