Suppose two billiard balls of same mass $m$ moving in the same axis $x$ with the same velocity and at some time $t=0$ they collide. No other forces are acting on the two billiard balls. Therefore the total momentum before the collision must be equal to the total momentum force after the collision, that is:$$\overrightarrow{P}_i=\overrightarrow{P_f}=0$$ But we can have zero total momentum even if the two balls move in opposite directions in $y$ axis with the same velocity after the collision. Both momentum and energy are then conserved. So, how one can predict the direction where the balls will move after the collision? (If the direction of force during collision is known then the direction can be predicted. But there isn't a general rule for the direction of force when two objects collide).
In the ideal case the forces act along the line joining the centres of the two balls.
Farcher
  • 104,498
The scenario you present (balls not rebounding along the previous direction) is actually what usually happens in real life. the direct rebounding only happens if the initial velocities are co-linear. In the case of one ball at rest, then the velocity vector of the moving ball would need to be directed toward the center of the resting ball.
If the velocity vectors are not co-linear, then the balls will not have a direct impact, and the post-collision directions will be rotated from the original. to predict the directions you would need to know the offset of the velocities or the angle between the center-to-center line and the velocities.
And since you're talking about billiards, the spin ("English") of each ball will affect the post-collision directions, too.
Bill N
  • 15,522
