Sometimes a system's internal chemical energy is converted into mechanical energy and thermal energy with no work being done on the system by external forces. For example, at the beginning of this section we described the energy conversions that take place when you start running. In order to move forward, you push back on the floor and the floor pushes on you with a static frictional force. This force causes you to accelerate, but it does not do work. It does no work because the displacement of the point of application of the force is zero (assuming your shoes do not slip on the floor). Because no work is done, no energy is being transferred from the floor to your body. The kinetic energy increase of your body comes from the conversion of chemical energy derived from the food you eat.
So when we walk on the ground, friction does no work, only providing grip so as our chemical energy can become kinetic energy.
But let's say I walk forward/accelerate on a moving train, with the train moving at a constant speed. And there is an observer sitting watching this outside. They would see friction doing positive work on me relative to the ground?
The train is moving at constant velocity. The energy the person gains comes from internal energy, like chemical potential energy. So why does it look as if friction from the train to the person is doing work. I'm confused, what am I seeing. This makes no sense to me.
Edit/picture is to end question about "does friction do work walking". This questions is not about that. I am trying to understand how in one frame, lets say walking, friction does no work, but in another frame, it appears it does. Maybe I am just confusing reference frames... not sure
BioPhysicist
  • 59,060
But let's say I walk forward/accelerate on a moving train, train at a constant speed. And there is an observer sitting watching this outside. They would see friction doing positive work on me relative to the ground?
This is correct. The power, $P$, of a contact force, $\vec F$, is given by $P = \vec F \cdot \vec v$ where $\vec v$ is the velocity of the material at the point of contact. Since $\vec F$ is in the same direction as $\vec v$ the power is positive meaning that positive work is done on the person.
The train is moving constant. The energy the person gains comes from internal. So why does it look as if friction from the train to the person is doing work. I'm confused, what am I seeing. This makes no sense to me
Actually, not all of the energy that the person gains is coming from the internal energy in the ground frame. Assuming a perfectly efficient conversion of chemical potential energy into mechanical energy, the amount of mechanical energy gained (in the ground frame) by the person is greater than the amount of chemical energy lost (which is Galilean invariant). The difference is precisely the positive work done by the contact force.
By Newton's 3rd law there is an equal and opposite contact force operating on the train. This force is in the opposite direction of $\vec v$ so negative work is done on the train. Since the train is travelling at a constant speed that means that its engine (unsurprisingly) must be supplying power.
So the mechanical energy gained by the person comes both from the internal conversion of chemical energy to mechanical energy and also from the energy of the train through the work done by the friction force in this frame. To see this quantitatively it is useful to consider a simplified example, such as a spring or something similar.
Dale
  • 117,350
Let's imagine a person at rest with respect to the surface they're standing on, and they push off that surface to move forward at a speed of 1m/s forward (relative to the surface).
Using a ground reference, this is pretty simple. Assume the person is 50kg, then the minimum energy for the step is: $$\Delta E = E_f - E_i$$ $$\Delta E = 0.5 (50\text{kg})(1 \text{m/s})^2 - 0 = 25\text{J}$$
Now let's imagine this happening on a moving train. We suppose the train is already at a speed of 5m/s. What's the energy change now?
$$\Delta E = 0.5 (50\text{kg})(6 \text{m/s})^2 - 0.5 (50\text{kg}) (5 \text{m/s})^2 = 275\text{J}$$
So when looking at the interaction from a different reference frame, the person has added much more energy. We resolve this problem by saying that besides the work the legs are doing, the train is also doing work on the person.
If the person took 1 second to make the step, then the force off the surface must be $F = ma = (50\text{kg})(1\text{m/s}^2) = 50 \text{N}$.
In the ground frame, we would say the train's work (or the work from friction) was therefore $$W = Fd = Fvt = (50\text{N})(5\text{m/s})(1s) = 250\text{J}$$
And that 250J exactly accounts for the difference in energy between the two cases.
If we just looks at this happening, walking inside the train, why don't we have to account for this other 250J energy? Shouldn't we have too? That is my confusion, when we are on earth walking why dont we have to account for any of these affects?
You have to account for it if you care about the actual energy of the train. This 250J came from the train. Now the massive train has a huge amount of KE, so this 250J will be a tiny fraction of that amount. But the faster the train is going, the more energy this change in speed represents.
Since the earth is even larger, as long as we're in a frame where its speed is small, we can usually ignore the energy exchanged with it.
BowlOfRed
  • 42,997
  • 68
  • 123
