The idea of the holographic principle is that all the data about what's inside a volume can be discribed by fields on it's boundary.
But... isn't this just obvious calculus?
e.g. take a field in polar coordinates $\phi(r,\theta,\rho)$ with $r<1$.
The boundary of this volume is at $r=1$. We can define an infinite set of fields:
$$\Phi_n(\theta,\rho) = \frac{\partial^n}{\partial r^n}\phi(r,\theta,\rho)|_{r=1}.$$
These fields live on the boundary. The field inside the boundary can be reconstructed by a simple Taylor series:
$$\phi(r,\theta,\rho) \equiv \sum_{n=0}^{\infty}\frac{1}{n!}(r-1)^n \Phi_n(\theta,\rho).$$
So it's easy to create a set of fields on the boundary that are equivalent to fields on the interior. Assuming the fields are analytic. So what's so special about the holographic principle?
In the holographic principle for quantum gravity the DOFs are encoded on a spacetime codimension-2 Cauchy surface. A conventional hyperbolic system has a spacetime codimension-1 Cauchy surface. A Taylor series $f(x)=\sum_{n=0}^{\infty}\frac{f^{(n)}(0)}{n!}x^n$ is typically not viewed as an example of holography. For starters because we usually don't require analyticity of physical fields. In fact, typically only a finite number of derivatives are important in physical theories, cf. e.g. this & this Phys.SE posts. See also this related Phys.SE post.
