I am collecting the intensity of radiation as a function of wavelength. I want to take this data and average it so that I can have an average intensity for a spectral band. In my average, I want to weight by two factors – the uncertainty and another factor dictated by Planck's curve, as I care more about values that correspond to high intensity.
I also want to estimate the uncertainty associated with this twice-weighted average, but I'm unsure how to do this.
I have seen some posts here, for example this. However, I don't know if the error for this average will propagate as described there or if the second weighting complicates matters.
If you have a smooth function, the data points are not (!) statistically independent. Instead, neighbouring data points are similar and therefore correlated. This complicates things, mathematically. Thus, one way to tackle this problem could be as follows:
  1. First calculate the correlation length of the dataset. Suppose you find that the correlation length is $r$.
  2. Now, only consider every $r^{th}$ datapoint. Thus use the simple formula \begin{align} y &= \frac{\sum_{i=1}^N w_i x_{i}}{\sum_{i=1}^N w_i} = \frac{1}{N \bar{w}}\sum_{i=1}^N w_i x_{i} ~~~\textrm{where $w_i$ are the weights} \\ \Rightarrow \sigma_y^2 &\approx \sum_{i=1}^N \left( \frac{\partial y}{\partial x_{i}} \right)^2 \sigma_{x_{i}}^2 = \frac{1}{(N \bar{w})^2} \sum_{i=1}^N w_i^2 \sigma_{x_{i}}^2 \end{align} Mathematical details: I implicitly replaced the dataset $\{x_i\}$ by $x_{1+i\cdot r}$. Thus, I took only every $r^{th}$ data point.
The described reduction of the dataset is unsatisfactory, because we do not use the full information contained in the dataset. Therefore, you might be interested in using the mathematically more proper formula $$ \sigma_y^2 \approx \sum_{i=1}^N \left( \frac{\partial y}{\partial x_{i}} \right)^2 \sigma_{x_{i}}^2 + 2 \sum_{i = 1}^{N-1} \sum_{j = i+1}^{N} \frac{\partial y}{\partial x_{i}} \frac{\partial y}{\partial x_{j}} Cov[x_i, x_j] $$ Here we included the second term of the Taylor expansion, where $Cov[x_i, x_j]$ denotes the covariance between $x_i$ and $x_j$.
NotMe
  • 9,818
  • 15
  • 32
