It is clear that the gravitational pull diminishes with increasing distance, but I can't find the answer to whether there is a point where it becomes "exactly zero". Is there such distance? Is it calculable?
gunakkoc
  • 101
No. Gravity is a fundamental force whose range is infinite. The same applies to the electromagnetic force. For more info see
http://hyperphysics.phy-astr.gsu.edu/hbase/Forces/funfor.html
Hope this helps.
Bob D
  • 81,786
Yes, in a way. Gravitational force decreases inside a planet. At the center it is 0 because all parts of the planet pull outward symmetrically. The formula you used only applies outside.
Also at an infinite distance, the force would be 0. That is of course a bit of a cheat. The limit is 0, but you can't find a point where the value is the same as the limit.
mmesser314
  • 49,702
Not in Newtonian gravity, but in relativistic cosmology. The most suitable metric to study this problem is the Schwarzschild De Sitter metric. By setting $\dot{r}=\dot{\theta}=\dot{\phi}=0$ we get
$$\ddot{r}=\frac{\lambda c^2 r}{3}-\frac{G M}{r^2}$$
where $\lambda$ is the cosmological constant. By setting $\ddot{r}=0$ and solve for $r$ we get
$$r=\sqrt[3]{3 G M / \lambda / c^2}$$
which is the coordinate radius at which the test particle is neither attracted nor repelled and keeps a constant distance to the dominant mass $M$.
Another approach is to set the recessional velocity equal to the Newtonian orbital velocity
$$H r = \sqrt{G M/r}$$
and solve for $r$, then we get
$$r=\sqrt[3]{G M / H^2}$$
Since in a De Sitter universe the Hubble and the cosmological constants are related by
$$H=\sqrt{\lambda c^2/3}$$
this is the same expression for $r$ as obtained above.
Yukterez
  • 14,655
