Consider the case of an accelerating motorcycle, the engine converts potential energy into mechanical energy which is used to generate a Newton third law pair of forces at the rear tire's contact patch, a backwards force exerted from the contact patch onto the roar, coexisting with a forwards force exerted by the road onto the contact patch. To simplify things, assume there are no losses in the process, no drag, no rolling resistance, etc., so that any decrease in PE (chemical potential energy of the fuel/battery) ends up as an increase in KE (kinetic energy).
The "abstract" object in this case is the contact patch of the rear tire. Although there is no relative motion between the surface of the tire and the road at the contact patch (static friction), the contact patch itself is moving at the same velocity as the motorcycle (ignoring load related deformations). This is easier to visualize if you use the center of area of the contact patch as the instantaneous position of the contact patch.
The road can't generate power, but the point of application of the force the road exerts onto the contact patch moves with the same velocity as the motorcycle. So power could be stated as the force exerted by the road times the velocity of the point of application of that force, the contact patch, which is the same as the velocity of the motorcycle (assuming a flat road).
The road also can't perform work, but the integral sum of force(versus position of contact patch) times distance the contact patch moves, could be used to calculate the "work" done that originated from the engine.
I did a rethink on this. Power = force exerted on motorcycle · velocity of motorcycle. The fact that the road is not moving doesn't affect the road's ability to exert a force on the moving motorcycle, because it applies the force to the contact patch of the tire, where the tread is not moving with respect to the road, but is moving with the negative of the motorcycles velocity with respect to the motorcycle. Due to the rolling motion and the torque from the engine, the motorcycle's tire and wheel transmit the force from the road onto the rear wheel axis with the same force from the road and at the velocity of the motorcycle. The road could be considered as part of the power transmission sequence that uses the engine's power to accelerate the motorcycle.
In this case the velocity of the contact patch is the same as the velocity of the motorcycle, but consider a drum being angularly accelerated by a spinning tire, in this case the contact patch is not moving, but the surface of the drum is. The drum could be replaced with a cable that loops between two spools, so that the acceleration of the cable at the contact point is linear. In this case, the contact patch is not moving, and power = force exerted on cable · velocity of cable.
The fact that the tire surface is not moving with respect to the road at the contact patch is the reason that a non-moving road can apply a force to a moving motorcycle.
So what I refer to as an abstract object is just a way of referring to something that moves at the same speed as the object the force is being applied to, and was my attempt to deal with rolling motion of the rear tire in the case of the motorcycle.
The point of application of force being at the contact patch does have consequences, such as a wheelie if the acceleration is sufficient.
From a strict physics viewpoint, the interface between tire and road convert angular power (torque times angular velocity) into linear power (force x linear velocity), so no net work is done. However, it is common practice to state what the rear wheel horsepower is for a motorcycle, and this can be calculated as force times speed. This can be done using a chassis dynamometer, but it is also possible to determine force through torque sensors (tranducers), allowing rear wheel horsepower to be determined in real time while riding, and some riders buy the equipment that includes torque sensors and data recording for their (racing) track bikes.
rcgldr
  • 557
The torque applied to the wheel by the engine causes causes a backward force on the road surface. Per Newton's third law the backward force on the road causes an equal force acting forward on the tire by the road, at the location you call the "contact patch". This forward acting force is due to static friction between the tire and the road. It will continue to equal the backward force as long as the maximum static friction force of $μ_{s}N$ is not exceeded, in which case the tire will slip. For the maximum static friction force $μ_s$ is the coefficient of static friction between the tire and the road and $N$ is the normal force acting on the drive wheel due to that portion of the motorcycles weight acting down on the drive wheel.
Assuming no drag, rolling resistance, or other external (to the car) forces are acting on the motorcycle, then the static friction force is the only external force acting on the motor cycle and is therefore directly responsible for propelling it forward. The road is, in fact, doing work on the car to propel it forward.
This fact is somewhat difficult to understand because the road is clearly not an energy source. The source is the engine that creates the backward force on the road which, in turn, creates the forward static friction force that is responsible for doing the work. So the energy comes from the power transmission system which transfers energy from the source (fuel in the engine) to the car by virtue of a series of interactions ultimately ending up as the static friction force of the road acting on the car.
Hope this helps.
Bob D
  • 81,786
Power is defined as: the rate at which work is done or the rate at which energy is transfered from one place to another or transformed from one type to another. https://physics.info/power/
“the rate at which work is done” is given by the formula $P=\vec F \cdot \vec v$ where $\vec v$ is the velocity of the material at the point of application of the force. In the example of a lossless motorcycle the point of application of the force is the bottom of the tire, which has $\vec v= 0$.
However, it is exactly this point which is in question. Is the correct velocity for calculating the power equal to the velocity of the material at the contact patch or is it equal to the velocity of the contact patch? Therefore, to resolve this we will look at the other parts of the definition to see if one interpretation of $\vec v$ is more consistent with the remainder of the definition than the other.
“the rate at which energy is transfered from one place to another”. Due to the conservation of energy, if energy were transferred at the contact patch then the energy of the car would change. Since the energy of the car does not change it is clear that the rate at which energy is transferred across the contact patch is zero. So by this part of the definition the power is zero. This is consistent with $\vec v$ representing the velocity of the material at the contact patch, but inconsistent with $\vec v$ representing the velocity of the contact patch.
There do exist passive devices which transmit power from one location to another, such as shafts, ropes, gears, and levers. However, in all such devices there is one location on the device where positive $P$ is done and another where an (ideally) equal amount of negative $P$ is done. This not the case at the contact patch.
“or transformed from one type to another”. At a typical contact patch the only transformation of energy is from mechanical energy to thermal energy. By assumption that is zero in this case. In this problem the only transformation of energy is in the engine where energy is transformed from potential to mechanical. It therefore makes sense to speak of the power of the engine despite the constancy of the vehicle’s total energy. But at the contact patch any energy is mechanical and remains mechanical. So this portion of the definition is also consistent with $\vec v$ representing the velocity of the material at the contact patch, but inconsistent with $\vec v$ representing the velocity of the contact patch.
Therefore, both of the other parts of the definition of power indicate that the power provided by the contact patch is zero. This corresponds with the definition that $\vec v$ is the velocity of the material at the contact patch.
The reason this question tricks so many people is because the force from the road does change the motorcycle’s momentum. However, it is important to know that momentum and energy are distinct concepts. They are related but not the same. A force is the rate of change of momentum, not the rate of change of energy. Therefore it is possible for a force to change an object’s momentum without changing its energy. This is one example, though there are many other similar examples.
In the end the mechanical power transferred by a force $P=\vec F \cdot \vec v$ is always calculated using the velocity of the material where the force is applied, which is zero for the motorcycle example.
Dale
  • 117,350
