(Note: Please see addendum at bottom for paper references relevant to the question.)
The question of how to synchronized clocks was first addressed by Einstein himself in his famous special relativity paper, and it occupies much of the discussion in that paper prior to him getting into electromagnetics.
What Einstein suggested was this: Both observers have identically constructed clocks, and from that they assume that the clocks keep equal time. But how do they make sure they have the same time, not just the same tick rate?
Einstein suggested what would now be called a handshake: A sends a time stamp to B via a light beam, and B immediately sends his own time stamp back to A. When A receives that "handshake" back from B, she knows both how long it took to get the information and what time B had (by symmetry) halfway through that time period.
That's enough information for A to update her clock to that of B, plus half of the delay in the response to take care of how long it took B's time stamp to arrive.
There are other more subtle issues such as whether B might be moving relative to A, but those too can be taken care of using only light beams by ensuring there is no frequency shift (Doppler effect) when viewing the returning beam.
Not only is this procedure pretty straightforward, it's useful. For example, you would not be reading this message if the electric company you use didn't use the same kind of synchronization procedure to ensure that distant parts of an electrical network are all very precisely in sync with each other. If they did not do that, the generators would get out of phase and start destroying each other. Meaningful time synchronization thus is not some abstract concept, but something real and very much needed for anything networked. The important point for getting this type of synchronization in time is that the various parts must not be moving relative to each other. That's where special relativity kicks in, not in synchronization itself.
There is another technique that you touched on, which is this: If you move a clock very slowly from one location to another, the relativistic effects can be made very, very small -- so small in fact that you really can always make them small enough to ignore them. It's not nearly as practical as Einstein synchronization, but it comes in handy at times.
Now, as for dividing up the rulers, yes, you cannot get infinitely small. But you can actually do very well at it simply by creating networks of very small clocks. Many computer networks are actually pretty decent examples of that. However, my favorite image is that of an entire region of space filled with tiny, tiny clocks, say a millimeter across each, with each clock constantly synchronizing with its nearest neighbors.
As Einstein himself pointed out, synchronization is a transitive operation, so having all those clocks talking to each other in that fashion eventually leads to an entire region of space filled with meaningfully synchronized particle-like clocks. Add a bit of data recording, and you can also use that network of particle-like clocks to keep that region of space both highly synchronized and capable of collecting data about both itself and other objects.
Even more interesting, if another object goes sailing through such a region at high speed, it can in principle extract a very exact time from each of the particle-like clocks with which it collides. The time is exact because the contact is "proximate" or touching, which eliminates the usual spacetime ambiguities when exchanging data between frames. The fast-moving object thus can "read" exactly what time the network of particle-like clocks thinks it is at each point of its journey, and vice-versa.
Surprisingly, and not very obviously, even this concept is in Einstein's paper after a fashion, for this reason: He invokes the idea of a rod moving through another frame and "reading" the time of that frame at each end of the rod. As it turns out, the only way you can do that is by creating a synchronized network of very tiny clocks that can "touch" each end of the rod as it passes. Any scheme that uses light (versus proximity) to pass the same information immediately becomes ambiguous, since different frame would interpret the message passing as different "mixes" of space and time. Proximate contact removes that, and enable Einstein's original moving-rod though experiment to be realizable in real space with real equipment.
I have never seen a name for the idea of asymptotically shrinking, particle-like, data-collecting, fully networked and fully synchronized nano-clocks occupying a volume of space, but it's a straightforward and definitely doable extension of things that modern communications systems do all the time. I like to call this idea of nano-sized clocks a synchronized network of observing particles, for which the acronym is, well... snoop.
So, if you want to do Einstein's moving rod experiment in real life, you will pretty much have to create some form of snoop first. There are actually much easier ways to do it than building real nano-clocks -- cloud chambers with carefully timed imaging certainly come to mind -- but the concept of a snoop helps analyze how you would go about doing many somewhat obscure-sounding special relativity experiments without getting lost in ambiguous data.
Please notice that I've intentionally gone in a somewhat different direction from what I think your suggestion is, which is to use a single clock with photon world lines extending out from it. The single central clock works great for defining a single cell of space and time, but I think you would find that you would end up with just one large-granularity pendulum clock by the time you work out all the details of the idea. You can do a lot with one well-defined cell of that type, but the fact that you can't even do Einstein's very first special relativity thought experiment (the moving rod) requires multiple synchronized clock cells is a pretty good argument that synchronization and multiple cells (multiple identical clocks) will also be needed to collect enough data to test even special relativity in detail, let along general.
If on the other hand you accept the idea of a "snoop limit" at which you can approximate synchronized clocks at point in a region of space to whatever level of detail is sufficient for your particular experiment, I think you'll end up with a much more satisfying (and experimentally unambiguous) result. In terms of those light pendulums I mentioned:
... you network a large number of them together by having them touch on their side corners. If the central clocks can also collect data, that's actually the more precise way to define a snoop.
Addendum 2013-02-02: Several relevant online references
As a result of the excellent information added via @RetardedPotential's answer, I now know the "standard" name for rho cells within the curved-space community: causal diamonds. The beautiful causal diamond diagram in the link I just gave is from this 2009 blog entry by theoretical physicists Sabine Hossenfelder and Stefan Scherer. From the variety I'm seeing in searching for examples, there does not seem to be any single highly standardized way of labeling the backward and forward light geodesics that form the sides of causal diamonds. I labeled them ${\pi_\phi}^-$ and ${\pi_\phi}^+$ for the backwards ($-$) and forwards ($+$) photon coordinates ($\pi$) of frame $\phi$, but I may relabel them if something more standard exists.
More importantly, the idea of using cells small enough to ensure that space is locally flat -- the same smoothness assumption that underlies calculus -- has also been explored! I call such networks snoops, but the 2007 G.W. Gibbons and S.N. Solodukhin paper The geometry of small causal diamonds (Physics Letters B, Vol. 649, Issue 4, 7 June 2007, p.317–324) clearly recognizes this same idea and explores it from the perspective of analyzing curved space.
And wow! Here's what looks to be a very relevant to fine-grained causal diamond analysis from just a couple of months ago:
The Discrete Geometry of a Small Causal Diamond, by Mriganko Roy, Debdeep Sinha, and Sumati Surya. Submitted to arXiv on on 4 Dec 2012
So, Haskell Curry, you may want to check out the above references as starting points if you are interested in fine-grained mapping of curved spaces.
(My own SR interests in snoops remain a bit tangential to curved spaces... um, did I just make a pun?)
2013-02-03
Back in 2007, @lubosmotl summarized a talk by Raphael Bousso in which Bousso mentions causal diamonds in the context of his holographic universe idea. The phrase is clearly older, e.g. see this 1999 mention of causal diamonds by George Svetlichny. Most likely it was a common catch-phrase in the 1990s for the straightforward relativity concept of intersecting forward and backward light cones.
My rho cells necessarily have the same geometry as causal diamonds, but that's about as far as the resemblance goes. By definition a rho cell has an unaccelerated rest-mass clock as its spine, and uses that clock to define $\tau_\rho$, $t_\rho$, and $l_\rho$, the last being isotropic only within clock frame. The clock could be as simple as a muon, and the reflectors could be replaced by photon exchanges between clocks. However, without a rest-mass spine, I don't readily see how a causal diamond can have a cause to be causal about, so to speak.
