Usually force of surface tension acts downwards , but in this problem , the direction is given upwards in my textbook. Am I missing a concept here , or the book is wrong? Please do help.
Surface tension is parallel to the surface. But if you add up all the surface tension forces on the drop, the drop is being supported against gravity. That is, the net force due to surface tension on the drop is upward.
S. McGrew
  • 25,240
  • 32
  • 81
