I'm not sure how to approach the following problem. Consider an infinitely thick walled spherical pressure vessel with undeformed internal radius $a$ and outer radius $b\rightarrow\infty$ made of a linear elastic material where, in its undeformed state, the pressure inside the vessel $P_i$ is equal to the outside pressure $P_o$, see figure.
If $P_i$ is increased the inner wall is deformed to $a'$. How do I calculate $a'$ as a function of $P_i$ for a linear elastic material?
I should then be able to integrate $P(a')dV$ to find the work done, which should be equal to the strain energy stored in the vessel. Is this correct?
Update:
I've made some progress. Following this answer: Stress in a thick-walled pressure vessel the displacement, $u$, of the material in the sphere can be written
$u(r)=\frac{P_i-P_o}{4G}\frac{a^3}{r^3}r$,
where G is the shear modulus of the material. So if $a'=u|_a+a$,
$a'=a(\frac{P_i}{4G}+1)$.
Or, in a more convenient form,
$P_i=4G(\lambda-1)$
where $\lambda = a'/a$.
I'm still not sure how to find the strain energy stored in the sphere however..
