In the Gaussian (CGS) system of units, the unit of electric charge (statcoulomb) is derived from the units of length, mass and time. Using Coulomb's law, we find that the dimension of electric charge is $$\text{[mass]}^{1/2} \text{ [length]}^{3/2} \text{ [time]}^{−1}$$
According to this answer the Kelvin is the unit of (thermodynamic) temperature used with the Gaussian system of units. However, since the temperature is related to the average translational kinetic energy of particles, I would like to know if it is possible to derive a unit of temperature (let's call it statkelvin) from the units of length, mass and time (in a way similar to the statcoulomb).
Would such a unit of (thermodynamic) temperature be a usable alternative to the Kelvin for scientific purposes? (if we disregard the historic advantage of the Kelvin)
What would be the physical law used to derive this unit of temperature? And what would be the resulting dimension of that statkelvin? (in terms of mass, length and time)
RalphS
  • 123
Just change Boltzmann's constant.
The equation you're referring to is probably a version of the equipartition theorem:
$$\langle K\rangle =\frac{n}{2} k_BT$$
where $\langle K\rangle$ is the expectation value of kinetic energy of a particle, and $n$ is the number of degrees of freedom of the system in question. Since $K$ is expressed in units of ergs, and you want to create a unit "statkelvin" for $T$, then simply let $k_B$ equal some value, with units of ergs/statkelvin. The value chosen for $k_B$ will set the "size" of the statkelvin.
In CGS, the units of the Boltzmann constant are ergs/K, and its value is such that measurements of kinetic energy in ergs and of temperature in K are compatible.
You could also get rid of Boltzmann's constant entirely, making it dimensionless and setting its value to 1. This would mean that temperature has the same units of energy, meaning that the statkelvin would be equivalent to the erg.
