I have read the answer to this question from Eric. That answer is still from the point of view of a standing observer that sees the traveler spending infinite amount of energy. My question is asking for what happens from a traveller's point of view.
I know from standard traveller's point of view, the rest of the universe would finally reach the speed just below the speed of light moving away from him, that even though he keeps accelerating, he would never see himself moving faster than light relative to the rest of the universe. He would also see distances shrink to almost zero and time is slowing down to almost frozen, but none would eventually reach exactly zero and frozen, let alone be negative and moving backward in time. In short, please note that I don't at all suggest there would be two objects moving relative to each other faster than light.
However, also from his point of view, everything looks normal as according to him his mass is not increasing at all, he doesn't need infinite amount of energy to keep accelerating. The result of his acceleration (or energy spent) could not be just he is moving in a constant speed (or for nothing). For when if it does happen, we could not just maintain the contracted length would be just very close to zero, or time would be just very close to frozen, because e.g. the SR equation itself would not be valid. The only choice I could think of is to let length becomes negative and time is moving backward. So, he should see outside distances finally shrink to exactly zero and eventually points in front of him would become his behind. In the same manner, outside time should finally look frozen to him and eventually moving backward.
Note that he could still see light travelling at the speed exactly $c$, but the rest of the universe is starting to move closer to him (as points at his behind become his front and time is moving backward), thus neither principle of relativity nor relativistic speed limit is broken.
So, what prevents him from seeing all those phenomena happen?
Following, I would like to try to describe it in a more step-by-step manner to avoid confusion such I don't use / understand relativistic speed addition correctly :D)
Please note that I don't at all suggest that the traveler would see earth moving away from him faster than light.
Let we just stick to the point of view of the traveler. To him, as he is accelerating, he would continuosly see outside distances contract and outside time slows down.
Now he reaches the speed of $0.9999.... c$, he should see outside distances are very close to zero and outside time are almost frozen.
Of course to him, nothing to do with other frame of references, he calculates his speed reaches c -- again nothing to do with other frame of references, and continuously so, so according to his calculation which is simply $s = tg > c$, his speed should be faster than light. There should be nothing wrong with this.
In fact if he doesn't calculate it to $s = tg > c$, his energy would not be conserved. Because otherwise where does the energy he spent go if it doesn't accelerate his speed?
Now, he plugs in his states to SR equation and of course because he is using SR equation, he MUST still see light traveling at the speed exactly $c$, but then he will get the lenght and time become negative. It's weird obviously, but he still doesn't see earth moving away from him faster than light, so no violation here.
Instead speculatively we could guess that he would see earth now is coming to him while in the same time outside time is running backward to him.
Other than that, please note again that I don't at all suggest he is moving faster than light relative to others, so it doesn't violate relativistic speed addition, but just (relative) speed faster than light according to him, WITHOUT reference to any other frame of references at all.
