So I understand that the Lie algebra of $SO(1,3)$ is isomorphic to the Lie algebra of $SU(2)\oplus SU(2)$, and the Lie algebra of $SO(3)$ is isomorphic to one copy of $SU(2)$ (at the group level we have $SO(3)\cong SU(2)/Z_2$).
I guess my question is in two parts:
  1. In ”Physics from Symmetry” by Schwichtenberg, he says that the covering group is more fundamental - i.e. by considering $su(2)$ instead of $SO(3)$ we get spin.
  2. As far as I am aware, if we take the exponential map of a Lie algebra homomorphism/representation then we get a representation of the group. This would imply $SO(3)$ is a representation of $SU(2)$, but how can there exist a homomorphism from $SU(2)$ to $SO(3)$, if each element in $SU(2)$ gets identified with two elements of $SO(3)$?
DanielC
  • 4,497
  • 25
  • 39
$SO(3)$ irreps (irreducible representations) naturally only contain spin $0,1,2,\dots$
$SU(2)$ introduces half integer irreps.
The fundamental representation of $SO(3)$ is a $\bf 3$, consisting of the rotations around the three axes:
$\left(\begin{array} {c c c} \cos(\phi)& -\sin(\phi) &0\\ \sin(\phi) & \cos(\phi) & 0 \\ 0 & 0 & 1\end{array}\right)$
$\left(\begin{array} {c c c} \cos(\psi)& 0 & \sin(\psi) \\ 0 & 1 & 0 \\-\sin(\psi) & 0 & \cos(\psi) \end{array}\right)$
$\left(\begin{array} {c c c} 1 & 0 & 0 \\ 0 & \cos(\chi)& -\sin(\chi) \\ 0 & \sin(\chi) & \cos(\chi) \end{array}\right)$
It corresponds to $j=1$, the spin-1-representation. Tensor products generate all other representations with $j\in \mathbb{N}$.
$SU(2)$ is more fundamental, since it contains besides representations with $j\in \mathbb{N}$ also half-integer spins $j\in \frac{\mathbb{N}}{2}$.
The fundamental representation $\bf 2$ of $SU(2)$ is represented by the $2\times 2$-complex-valued matrices, obtained by exponentiating the Pauli-spin matrices. It corresponds to $j=\frac{1}{2}$. From it, all integer and half-integer representations can be generated.
psitae
  • 1,455
  • 15
  • 29
p6majo
  • 443
For myself, I answered part 1 of your question empirically. There are objects (eg: electrons) in the world which only return to their original state after rotation by $4\pi$ (not $2\pi$). These "half integer spin" objects also have an even number of states (ie: z projections of angular momentum). No representations of $SO(3)$ provide these properties, but representations of $SU(2)$ do and also provide representations to rotate all the integer spin particles too. Thus $SU(2)$ more completely represents nature (ie: is more fundamental).
Gary Godfrey
  • 3,428
