Is conduction at the atomic level simply electromagnetic energy (photon) transfer, coupled with momentum transferred during collisions?
Can conduction be summed up as thermal radiation + momentum transfer?
Thermal conduction, or more properly called heat conduction, can be summed up as the transfer of kinetic energy from a higher temperature substance where the internal kinetic energy is greater, to a lower temperature substance (or lower temperature region of the same substance) where the internal kinetic energy is less, by means of direct physical contact. Generally electromagnetic energy transfer does not play a role in heat transfer by conduction, but rather heat transfer by radiation which requires no medium.
The mechanism by which the kinetic energy is transferred, and the type of kinetic energy that is transferred (rotational, vibrational, and/or translational) depends on whether the substance is a gas, liquid, or solid. For a solid it also depends on whether it is metal or non metal.
Hope this helps.
Bob D
  • 81,786
