Let's consider a free scalar quantum field, at "a single point in time".
Let $p$ be a momentum state.
I could write this: $a^\dagger_p|0\rangle$ , and as far as I understand, this denotes a field with a single particle in a particular momentum state.
Now this can be expanded into position states. If I understand correctly, it is a superposition of single particle states at every position. But, the "amount" of particle at each position is infinitesimal (ie. the prefactors of eigenvectors in the position basis are infinitessimal. Equivalently there is 'infinitessimal chance' to find a particle at any position if there was an observation).
My problem comes when I try to consider the field at any point. It is like a harmonic oscillator, and we can calculate it by combining the ladder states in the same way. But in this case, at any point, we have a single inifinitessimal piece of 1 particle state, and all the rest (all the other contributions of the infinite points in the integral) are of the ground state. So what does the field look like? An infinitesimal deviation from the harmonic oscillator ground state? That seems awkward. Is that valid? Or is my understanding wrong? Or are single particle states not really valid on their own?
