Relativistic wavelength shift for a stationary source and an receding detector is given by
$\frac{\lambda_s}{\lambda_d}=\sqrt\frac{{1-\beta}}{{1+\beta}}=\frac{{1-\beta}}{\sqrt{1-\beta^2}}=\gamma(1-\beta)$
Now, the $\gamma$ can be explained as a result of Lorentz length contraction. In other words, distance between two points in the source frame will be Lorentz contracted when seen by a moving detector.
But how is the $(1-\beta)$ factor explained by the source?
In other words, the source sees the detector detect a higher frequency due to time dilation as well as due to its motion. It also sees the wavelength to be Lorentz contracted in the frame of the detector. How does the source explain the additional factor $(1-\beta)$ needed to explain the same speed of light measured by the detector?
Ritesh Singh
  • 1,519
How does the source explain the additional factor (1−β) needed to explain the same speed of light measured by the detector?
Let us say that the detector is a physicist with a clock, who measures the time it takes for one wave to pass her, then calculates the length of the wave to be: time * speed of light.
The source is an observer with the light source. This observer observes what the physicist does. The question was what does that observer observe, right?
So the observer notes that the clock is slow, which decreases the measured time by gamma.
Then he notes that the passing speed is speed of light - speed of physicist. Passing time is proportional to passing speed, and the length of the passing thing.
So the passing time t according to the observer is: length of the passer / passing speed = L / (1 - Beta).
The physicist measures passing time: t'= t / gamma =
(L / (1 - Beta)) / gamma
The length of the passing thing according to the physicist is the speed of that thing multiplied by t, and we have set c to 1.
So according to this derivation the correct formula is:
L' = (L / (1 - Beta)) / gamma
"Passing speed" is the same thing as "closing speed", see Wikipedia if not familiar with that latter term.
stuffu
  • 2,374
