While doing some lazy calculations, I came across a curiosity that I'm unable to interpret. It is well known that the cosmological constant $\Lambda \sim 10^{-52}~\mathrm{m^{-2}}$ is usually interpreted as a measure of the vacuum energy: \begin{equation}\tag{1} \rho_{\Lambda} = \frac{\Lambda c^4}{8 \pi G} \sim 5 \times 10^{-10}~\mathrm{J/m^3}. \end{equation} The Planck density is defined as this: \begin{equation}\tag{2} \rho_{\text{P}} = \frac{M_{\text{P}} \, c^2}{L_{\text{P}}^3} = \frac{c^7}{\hbar G^2} \approx 5 \times 10^{113}~\mathrm{J/m^3}. \end{equation} So the ratio of (2) to (1) is \begin{equation}\tag{3} \frac{\rho_{\text{P}}}{\rho_{\Lambda}} = \frac{8 \pi c^3}{\hbar G \Lambda} \sim 10^{123}, \end{equation} which is interpreted as the "$10^{120}$" crisis in fundamental physics (I'm very expeditive on this here).
Now, the entropy of the de-Sitter horizon is defined as this (in units of $k_{\text{B}}$): \begin{equation}\tag{4} S_{\Lambda} = \frac{A}{4 L_{\text{P}}^2}, \end{equation} where $A = 4 \pi \ell_{\Lambda}^2$ is the area of the de-Sitter horizon and $\ell_{\Lambda} = \sqrt{3 / \Lambda}$. The formula (4) is very controversial in the case of the de-Sitter spacetime (with $\Lambda > 0$). Whatever its status, it gives \begin{equation}\tag{5} S_{\Lambda} = \frac{3 \pi c^3}{\hbar G \Lambda} \approx 4 \times 10^{122}. \end{equation} This is almost exactly the same as (3) (except for the numerical factors $8 \Leftrightarrow 3$).
So my question is how should I interpret this "coincidence", i.e. that the ratio of energy density (3) is the same as the horizon entropy (5) ? AFAIK, the entropy has nothing to do with the discrepency in the energy density relative to the Planck density.
Cham
  • 8,015
As to the 'why' - from the holographic dark energy conjecture, the CCP and the BH entropy are in fact related. Eqn (1) and (2) can also be expressed $kg/m^3$ as:
\begin{equation}\tag{1} \rho_{\Lambda} = \frac{\Lambda c^2}{8 \pi G} \ \end{equation}
\begin{equation}\tag{2} \rho_{\text{P}} = \frac{c^5}{\hbar G^2} \end{equation}
In flat de Sitter space the Hubble radius $R_h$ is equivalent to the cosmic event horizon radius. Also: \begin{equation} \Lambda =\frac{3}{R_h^2} \end{equation}
The cosmological constant problem (CCP) can be expressed by observing that the number of degrees of freedom of dark energy in QFT is much too large to explain the observational data.
That is, the QFT approach relates degrees of freedom to a sphere volume $V$. We can see this easily if we can write (3) with $R_h=2L_{Planck}$ (the past cosmic event horizon); as opposed to using the future cosmic event horizon $R_h\approx 16.1Gly$ as per the OP:
\begin{equation}\tag{3} \frac{\rho_{\text{P}}}{\rho_{\Lambda}} = \frac{4}{3}\pi 2^3 = \frac{32\pi} {3}=V \end{equation}
The CCP can be overcome by considering the holographic principle which equates the actual number of degrees of freedom $N_s$ of a region to its area not its volume. This is equivalent to stating that the quantum vacuum energy in a region cannot be larger than a black-hole mass of the same size. Then the BH entropy relation comes in via:
\begin{equation} N_s=4S_{\Lambda}=16\pi \end{equation}
So we can write (3) as:
\begin{equation} \frac{\rho_{\text{P}}}{\rho_{\Lambda}} = \frac{2}{3}N_s = \frac{8}{3}S_{\Lambda}=\frac{32\pi} {3} \end{equation}
TLDR: The OP's numerical correspondence comes from the holographic-inspired solution to the CCP, which uses the BH (de Sitter) entropy.
Mr Anderson
  • 1,494
For my own convenience, I will use units where $\hbar=c=1$, and will ignore order 1 constants like 2 and $\pi$.
The entropy has to be a dimensionless combination of $\Lambda\sim H^2$ and $M_{\rm pl}$ (but we know it scales with the area of the horizon, so it's $M_{\rm pl}^2/H^2$.)
The cosmological constant problem can be expressed in any many forms, including $M_{\rm pl}/H$, $M_{\rm pl}^2/H^2$, etc. Since the quantity in the Einstein equations is $\Lambda\sim H^2$, that is the conventional way to express the cosmological constant problem.
So I think the answer is that they are both $H^2$ in units of $M_{\rm pl}$. G. Smith wrote the same thing in a comment above.
