14
I was reading an article by the Smithsonian Institute about the rising sea levels. In it, they mention how warmer water expands more, thus it helps to raise the average sea level. This makes perfect sense to me as I've always known that heat generally causes a substance to expand. But, I am very skeptical as to how much of a difference this makes, which is my question: how much expansion is caused by the rise in average global temperatures.
Now, I don't think the rise in average surface temperatures results in an equal raise in ocean temperatures, because most of the ocean, below 1,000 meters or so, hovers close to freezing year round. So, I dont think the whole of the ocean temperature rises in lock-step with the heating of the Earth's surface.
Specifically, I would like someone to calculate how much sea level rises due to a 1 or 2 degree warmer average temperature overall. As a secondary question, I would like to know how much surface temperatures affect ocean temperatures.
This is known as the steric component of sea level rise, and it is significant.
As a very rough indication of the size of the effect, if the top 1000 meters of the ocean warmed from 10 to 11 degrees C, sea level would rise by 18 cm. Calculations like this can be made using the equation of state of seawater, which is an empirical thing with lots of terms that gives you the density as a function of temperature, salinity, and pressure. You can read all about it in this article.
Ben51
  • 10,037
We can get the volumetric expansion coefficient $(\frac{0.000214}{C})$ from the link below. I'm going to run through this example for a $1\times1\times 3500 \space \mathrm{m}$ rectangular volume. Like the previous answer, I'll assume a one degree C change in temperature. 3500 m is the average depth of the ocean according to 2 seconds of google.
$V_1 = 3500 \space \mathrm{m}^3$
$\Delta V_2 = V_1\times c_w \times \Delta C$
$\Delta V_2 = 3500 \times 0.000214 \times 1 = 0.749\space\mathrm{m}^3$
So, for a one degree change in temperature, and the average ocean, there is a $0.749\space\mathrm{m}^3$ increase in volume. Our initial 1x1 area makes the sea level rise calculation very easy:
$\frac{0.794\space\mathrm{m}^3} {(1\times1)\space\mathrm{m}^2} = 0.794\space\mathrm{m}$ increase in sea level.
The area ends up cancelling out on both sides, so the answer should be the same for 100x100 or 1000x1000 meter area. The biggest assumption here is that the 'sides' of the ocean are completely vertical. I don't have nearly enough numbers to do the full calculation with shorelines, but this is where the numbers come from.
Coefficient of expansion reference: https://www.engineeringtoolbox.com/cubical-expansion-coefficients-d_1262.html
llama
  • 1,438
The answer is complicated and not a single number. The amount of thermal expansion for a given volume of ocean depends on depth (pressure), salinity, and temperature. That is, a 1C change from 10C to 11C will produce a different amount of expansion than 21C to 22C. What this means is that if you take a fixed quantity of energy (like, say, a gigajoule) and inject it as heat into different parts of the ocean, you will observe different amounts of thermal expansion. Thus, even an "average" warming of 1C across the entire ocean can manifest as a surprisingly wide range of thermal expansions, depending on the particular temperature deltas within each part of the ocean. That is, the final expansion will depend on the distribution of the thermal change.
The best we can do is build models which attempt to make reasonable inferences of the heat distribution and compare them to actual measurements taken by buoys, satellites, and other instruments. This is how the IPCC estimates the thermosteric component of mean sea level rise: https://www.nap.edu/read/13389/chapter/5. Some studies suggest that atmospheric-driven thermosteric expansion can be inferred down to 600m, while others suggest it penetrates further.
The EPA says that the average sea surface temperature (SST is a significant area of study all by itself) has increased on average about 0.07C/decade for the last century: https://www.epa.gov/climate-indicators/climate-change-indicators-sea-surface-temperature. Now, that probably doesn't sound like much change. Barely over half a degree for a whole century! But you need to consider that water has significantly higher density and specific heat than air, so the amount of energy it takes to warm a kg of air is much less than needed to warm a kg of ocean, let alone a m^3.
IPCC estimates conclude that the ocean has absorbed about 93% of the excess energy trapped during the last century or so: https://portals.iucn.org/library/sites/library/files/documents/2016-046_0.pdf. What this means is that 1C of atmospheric warming only corresponds to a small fraction of a degree of oceanic warming (hence, the 0.07C/decade).
Even so, thermal expansion is believed to account for at least half of all sea level rise in the last century or so. But to answer your question most directly, NASA documents that from 1970 or so, the ocean has risen about 5 mm/decade, with a corresponding ocean temperature increase of 0.015C/decade (note the different rates cited are due to vastly different timescales). This implies an observed ratio of about 333 mm/1C average ocean temperature increase in the top 700m of ocean. This is about 2x the rate given by @Ben51, and less than half given by @Anthony Herrera.
-2
I liked Lawnmower Man's answer. I would add that there's a possibility that the results are from observational data, and could include measurement bias, overstating the expansion.
I haven't noticed sea levels rising by 33cm all around the world, since 1970. Unless the land is also rising. I take my observations from shoreline reference points, in places like Fiji, New Zealand, South Eastern and North Western Europe, the US West Coast. South East Asia... All places where I have had family/beach side homes or businesses for 60-70 years, and that I visit multiple times per year.
Given there's no such anecdotal observational evidence for any sea level rises, in any of the areas I've been or go frequently, I wonder if there's another explanation?
Possibly, the land is rising, through earthquakes, or tectonic blistering in all places I go - it's possible. Except California is sinking, I believe we are told. The rest probably are rising, even the Pacific Islands I refer to (although many are sinking, as the Netherlands does).
Also possibly, there are a lot more measuring beacons all over the oceans, more easily capturing storm surges, coinciding with high tides... Which before, were unlikely to be numerically recorded, or if so, insufficiently to Sway mean sea level datum. Again from anecdotal evidence, I recall high tides, kind tides, etc, peaking in around 2012... Certainly in South East Asia.
For what that's worth.
Robert
