23
Let a box of volume $V$ contain $N$ monatomic gas particles, with total energy $E$. By considering the "volume" of phase space consistent with our macro-observables ($E$, $V$, and $N$), the multiplicity of this macrostate is (from Ref.1) $$ \Omega = \frac{V^N}{h^{3N}}\frac{2\pi^{3N/2}(2mU)^{(3N-1)/2}}{\Gamma(3N/2)} \,. $$
However, this expression is "incomplete" as it leads to a non-extensive entropy and hence Gibbs paradox. The fix for this is dividing by $N!$ (or "correct Boltzmann counting"), and the justification is usually: because particles are fundamentally indistinguishable in quantum mechanics.
I don't like the quantum mechanical justification, and Ref.2 sums up my feelings
If this reasoning were correct, then the Gibbs paradox would imply that the world is quantum mechanical. It is difficult to believe that a thought experiment from classical physics could produce such a profound insight.
Furthermore, I intuitively accept that the probability of a macrostate is proportional to the volume of phase space it covers. Dividing by $N!$ would "unfairly" reduce the probability of macrostates with larger number of particles. If $E$, $V$, and $N$ were all doubled, then the compliant region of phase space would increase drastically, more than just getting squared (i.e. doubling in entropy).
On the other hand, if entropy is not an extensive quantity, then neither is chemical potential $\mu$, and using the earlier "uncorrected" multiplicity, an infinite particle reservoir at constant temperature and pressure will have non-finite chemical potential, this can't be correct. (Related to: How do you experimentally measure the chemical potential of a gas?)
According to Ref.2,
systematic division by $N!$ for all particles of the same kind in mutually accessible states has no empirical consequences.
and it goes on to say that this is because dividing by $N!$ in closed systems do not affect the relative probabilities of macrostates (as $N$ is constant).
My understanding didn't really "click" after reading Ref.2, so I suppose I'm looking for a more detailed (or "intuitive") argument as to why correct Boltzmann counting has no empirical consequences.
  1. Schroeder, D. (1999). An Introduction to Thermal Physics. p.71.
  2. Versteegh, M., Dieks, D. (2011). "The Gibbs Paradox and the distinguishability of identical particles".
This question is similar to Why is the partition function divided by $(h^{3N} N!)$?, but I'm looking for a non quantum mechanical explanation specifically.
eugenhu
  • 555
After thinking about this for a bit, this is what I think could be an explanation.
Let $$ \Omega(V, N) = \frac{V^N}{h^{3N}}\frac{2\pi^{3N/2}(3Nmk_BT)^{(3N-1)/2}}{\Gamma(3N/2)}\Delta p $$ for some constant $T$ and where $\Delta p$ is some uncertainty in momentum. This is the multiplicity for a monatomic ideal gas at some constant temperature without correct Boltzmann counting.
I will first argue that the uncorrected multiplicity is actually valid, and that the Gibbs paradox can be averted.
For later convenience, we simplify the expression for $\Omega(V, N)$. \begin{align*} \Omega(V, N) &= \frac{V^N}{h^{3N}}\frac{2\pi^{3N/2}(3Nmk_BT)^{(3N-1)/2}}{\Gamma(3N/2)}\Delta p \\ &= \frac{(3N/2)^{(3N-1)/2}}{\Gamma(3N/2)}\left[\frac{(2\pi mk_B T)^{3/2}}{h^3}V\right]^{N}\sqrt{\frac{2}{mk_BT}}\Delta p \end{align*} Let \begin{align*} f(N) &= \frac{(3N/2)^{(3N-1)/2}}{\Gamma(3N/2)} \\ \lambda &= \frac{h}{\sqrt{2\pi mk_B T}} \\ \delta &= \sqrt{\frac{2}{mk_BT}}\Delta p \end{align*} then \begin{align*} \Omega(V, N) &= f(N)\left(\frac{V}{\lambda^3}\right)^{N}\delta \end{align*}
As per the usual setup for Gibbs paradox, consider the system below
where the left and right boxes are in thermal equilibrium but separated by a divider, and their volumes and number of particles are denoted by $V_1, N_1$, and $V_2, N_2$ respectively. We also constrain $N_1/V_1=N_2/V_2$, so both boxes have equal pressures.
It is then said that the total multiplicity of the system is $$ \Omega^{(?)}_\text{sys} = \Omega(V_1, N_1)\Omega(V_2, N_2) \,, $$ but I would argue that this is incorrect.
Suppose there is only one particle in each box, the system would then be characterised by the phase space coordinates $(\vec{q}_1,\vec{p}_1,\vec{q}_2,\vec{p}_2)$ where $\vec{q}_i$ is the position of particle $i$ and $\vec{p}_i$ is the momentum of particle $i$. The quantity $\Omega^{(?)}_\text{sys}$ would actually correspond to the multiplicity of a phase space distribution where the positions are distributed like so
However, this represents only a subset of the states that are consistent with our macrovariables (which was, one particle in each box). The position distribution should actually be
Because the particles are macroscopically identical (our macrovariables do not distinguish between them), there is no reason to believe that our system exists in only a subset of the available microstates as suggested by fig. 2. Of course, the system is definitely in one of the square regions in the position distribution, it cannot evolve between the two. If we wanted to insist that the system is in a specific square, we must have a way to prescribe this configuration using our macrovariables, but this is equivalent to requiring the particles be macroscopically distinguishable.
Another reason why $\Omega^{(?)}_\text{sys}$ is not the correct multiplicity is because it was calculated by multiplying the multiplicity of the left box subsystem, with that of the right box subsystem. This only works if the microstates of the total system can in some sense be factored into two uncorrelated "sub-microstates". If we look at fig. 3, the microstates cannot be factored into independent subparts. If $\vec{q}_1$ is a position in the left box, then $\vec{q}_2$ must be a position in the right box.
The system multiplicity should really be (in the one particle per box case) $$ \Omega_\text{sys} = \Omega(V_1, 1)\Omega(V_2, 1) \times 2 \,, $$ where we multiply by two to account for the correct volume of phase space. For a general number of particles per box, it is $$ \Omega_\text{sys} = \Omega(V_1, N_1)\Omega(V_2, N_2) \times {N_1+N_2 \choose N_1,N_2}\,, $$ where we have instead multiplied by a multinomial coefficient. Intuitively, we are saying that if $(\vec{q}_i,\vec{p}_i)$ is in a region of phase space compliant with our macroscopic prescription, then so will any permutation of the position-momentum pairs.
We now remove the divider between the boxes and let the particles mix. The system multiplicity is now $$ \Omega_\text{sys}' = \Omega(V_1+V_2, N_1 + N_2) \,. $$
This turns out to be equal (kind of) to the multiplicity before the divider was removed $\Omega_\text{sys}$, in other words, the Gibbs paradox was resolved when we correctly determined the system's initial multiplicity.
We now prove their "equality". \begin{align*} \Omega_\text{sys} &= \Omega(V_1, N_1)\Omega(V_2, N_2) \times {N_1+N_2 \choose N_1,N_2} \\ &= f(N_1)f(N_2)\left(\frac{V_1}{\lambda^3}\right)^{N_1}\left(\frac{V_2}{\lambda^3}\right)^{N_2}\frac{(N_1+N_2)!}{N_1!N_2!}\delta^2 \end{align*} Take the logarithm, i.e. calculate the entropy. \begin{align*} \ln\Omega_\text{sys} &= \ln f(N_1) + \ln f(N_2) + N_1\ln\left(\frac{V_1}{\lambda^3}\right) +N_2\ln\left(\frac{V_2}{\lambda^3}\right) + \ln\left(\frac{(N_1+N_2)!}{N_1!N_2!}\right) + 2\ln \delta \end{align*} Discard the constant term. \begin{align*} &\approx \ln f(N_1) + \ln f(N_2) + N_1\ln\left(\frac{V_1}{\lambda^3}\right) +N_2\ln\left(\frac{V_2}{\lambda^3}\right) + \ln\left(\frac{(N_1+N_2)!}{N_1!N_2!}\right) \end{align*} One can show that $\ln f(N) \sim 3N/2$ as $N\to\infty$. \begin{align*} &\approx \frac{3(N_1+N_2)}{2} + N_1\ln\left(\frac{V_1}{\lambda^3}\right) +N_2\ln\left(\frac{V_2}{\lambda^3}\right) + \ln\left(\frac{(N_1+N_2)!}{N_1!N_2!}\right) \end{align*} Recall that $N_1/V_1=N_2/V_2$. \begin{align*} &= \frac{3(N_1+N_2)}{2} + N_1\ln\left(\frac{V_1/N_1}{\lambda^3}\right) +N_2\ln\left(\frac{V_2/N_2}{\lambda^3}\right) + N_1\ln N_1 + N_2\ln N_2 + \ln\left(\frac{(N_1+N_2)!}{N_1!N_2!}\right) \\ &= \frac{3(N_1+N_2)}{2} + (N_1+N_2)\ln\left(\frac{V_1/N_1}{\lambda^3}\right) + N_1\ln N_1 + N_2\ln N_2 + \ln\left(\frac{(N_1+N_2)!}{N_1!N_2!}\right) \end{align*} Use Stirling's approximation. \begin{align*} &= \frac{3(N_1+N_2)}{2} + (N_1+N_2)\ln\left(\frac{V_1/N_1}{\lambda^3}\right) + (N_1+N_2)\ln(N_1+N_2) \\ &= \frac{3(N_1+N_2)}{2} + (N_1+N_2)\ln\left(\frac{(N_1+N_2)V_1/N_1}{\lambda^3}\right) \\ &= \frac{3(N_1+N_2)}{2} + (N_1+N_2)\ln\left(\frac{V_1+V_2}{\lambda^3}\right) \end{align*} Therefore, for large $N_1$ and $N_2$, $$ \ln\Omega_\text{sys} \approx \frac{3(N_1+N_2)}{2} + (N_1+N_2)\ln\left(\frac{V_1+V_2}{\lambda^3}\right) \,. $$
On the other hand, the entropy after the divider is removed is \begin{align*} \ln\Omega_\text{sys}' &= \ln(\Omega(V_1+V_2, N_1+N_2)) \\ &= \ln f(N_1+N_2) + (N_1+N_2)\ln\left(\frac{V_1+V_2}{\lambda^3}\right) + \ln \delta\\ &\approx \frac{3(N_1+N_2)}{2} + (N_1+N_2)\ln\left(\frac{V_1+V_2}{\lambda^3}\right) \\ &= \ln\Omega_\text{sys} \,. \end{align*}
Therefore, both $\Omega_\text{sys}$ and $\Omega_\text{sys}'$ lead to the same entropy, and there is no entropy gained by removing the divider.
As a side note, we've only shown that $\Omega_\text{sys}$ and $\Omega_\text{sys}'$ are equal when ignoring low order terms. Actually, we should not expect them to be equal exactly either. Before removing the divider, each box contained a definite number of particles, but after the divider is removed, the particle number in each box will be variable.
Thus, the Gibbs paradox is resolved without needing to use correct Boltzmann counting. If the "naive" approach to calculating the multiplicity was correct all along, why should we still insist on dividing by $N!$ to account for indistinguishability? How is division by $N!$ even justified?
There is one downside to not using correct Boltzmann counting, namely, entropy is no longer extensive. By an extensive entropy, I mean, one where the following is true. The entropy of a total system, is equal to the sum of the entropies of 'each subsystem when considered in isolation', regardless if some subsystems are "identical". This is equivalent to requiring that the multiplicity of the total system, be a product of the multiplicities of 'each subsystem when considered in isolation'. $$ \Omega_\text{total} = \prod_i \Omega_\text{subsystem $i$} $$ The multiplicity we have been using so far, clearly does not satisfy this property, we had to multiply by a multinomial coefficient to get the correct total system multiplicity; $$ \Omega_\text{total} \neq \Omega_\text{left box}\times\Omega_\text{right box} \,, $$ where $\Omega_\text{left box}$ is the multiplicity of the left box, when the left box is considered in isolation, and similarly for $\Omega_\text{right box}$.
There is a natural connection between how we have been calculating multiplicities so far, and correct Boltzmann counting. By rearranging the equation relating the total system multiplicity (before the divider was removed) and the multiplicities of the left and right boxes (when considered in isolation), we find \begin{gather*} \Omega_\text{sys} = \Omega(V_1, N_1)\Omega(V_2, N_2) \times \frac{(N_1+N_2)!}{N_1!N_2!} \\ \frac{\Omega_\text{sys}}{(N_1+N_2)!} = \frac{\Omega(V_1, N_1)}{N_1!}\frac{\Omega(V_2, N_2)}{N_2!} \end{gather*}
Correct Boltzmann counting absorbs the factorials into the multiplicities, so if we defined \begin{align*} \Omega_\text{sys}^{(B)} &\equiv \frac{\Omega_\text{sys}}{(N_1+N_2)!} \\ \Omega^{(B)}(V, N) &\equiv \frac{\Omega(V, N)}{N!} \end{align*} we restore the familiar $$ \Omega_\text{sys}^{(B)} = \Omega^{(B)}(V_1, N_1)\Omega^{(B)}(V_2, N_2) $$
Since $\Omega_\text{sys}^{(B)}$ differs from $\Omega_\text{sys}$ only by a constant multiple (total particle number $N_1+N_2$ is constant here), maximization of entropy defined as $k_B\ln \Omega_\text{sys}^{(B)}$ and maximization of entropy defined as $k_B\ln \Omega_\text{sys}$, will predict the same equilibrium states.
Essentially what we've shown is that the multiplicity of a monatomic ideal gas, calculated with or without correct Boltzmann counting (hereafter CBC), leads to an entropy which when maximized, predicts the same equilibrium states. One might justify the multiplicity calculated without CBC by Liouville's theorem and the ergodic hypothesis (to argue that macrostate probability is proportional to phase space volume). CBC multiplicity can then be rationalized as being empirically equivalent to the non-CBC multiplicity. Similar arguments could probably be made for legitimizing the use of CBC in other circumstances where CBC might not be "easily justified" from the foundational physical assumptions.
Why do we care about an extensive entropy?
I think the reason for this is that classical thermodynamics assumes that entropy is an extensive quantity, i.e. the entropy of the total system can always be calculated as the sum of entropies of each subsystem when considered in isolation.
For example, consider the system above in the setup for Gibbs paradox, and suppose $N_1/V_1\neq N_2/V_2$. We wish the find the equilibrium state when the divider is removed. Let $S_\text{sys}$ be the total system's entropy, and $S_1$ and $S_2$ be entropies of the left and right box subsystems (when considered in isolation) respectively. Assume entropy is extensive. \begin{align*} \frac{\partial S_\text{sys}}{\partial N_1} &= \frac{\partial S_1}{\partial N_1} + \frac{\partial S_2}{\partial N_1}\\ &= \frac{\partial S_1}{\partial N_1} - \frac{\partial S_2}{\partial N_2} \\ \end{align*} At equilibrium, $\partial S_\text{sys}/\partial N_1=0$. \begin{align*} \frac{\partial S_1}{\partial N_1} &= \frac{\partial S_2}{\partial N_2} \\ \mu_1 &= \mu_2 \end{align*}
If entropy is not extensive, this will not be true. Without correct Boltzmann counting, the total system multiplicity is (where we use $\Omega(E, V, N)$ so partial derivatives with respect to $N$ are when $E$ and $V$ are held constant, and not $T$ and $V$) \begin{gather*} \Omega_\text{sys} = \Omega(E_1, V_1, N_1)\Omega(E_2, V_2, N_2)\times\frac{(N_1+N_2)!}{N_1!N_2!} \end{gather*} The entropy is then, where $S_i = k_B\ln \Omega(E_i, V_i, N_i)$, \begin{gather*} S_\text{sys} = S_1 + S_2 - k_BN_1\ln N_1 - k_BN_2\ln N_2 + k_B\ln((N_1+N_2)!) - k_B(N_1+N_2) \end{gather*} Differentiate with respect to $N_1$, keeping $N_1+N_2$ constant. \begin{gather*} \frac{\partial S_\text{sys}}{\partial N_1} = \frac{\partial S_1}{\partial N_1} - \frac{\partial S_2}{\partial N_2} - k_B\ln N_1 + k_B\ln N_2 \end{gather*} At equilibrium, $\partial S_\text{sys}/\partial N_1 = 0$. \begin{gather*} \frac{\partial S_1}{\partial N_1} - k_B\ln N_1 = \frac{\partial S_2}{\partial N_2} - k_B\ln N_2 \\ \mu_1 + k_BT\ln N_1 = \mu_2 + k_BT\ln N_2 \end{gather*} This is a different (equally valid) equilibrium condition than was found before.
I don't think it is possible to "test" if gas particles in the real world have extensive or intensive entropies by "measuring their chemical potentials", since (my understanding is) when we "measure the chemical potential" of some chemical species, we are really only fitting parameters to a thermodynamic model that already assumes an extensive entropy, so using this method to prove that "entropy of real gases are extensive" might be circular and meaningless.
How do we justify correct Boltzmann counting for chemical interactions between subsystems of different chemical species, or when particle numbers are not conserved?
This is a question that came to my mind that others might have to. Ultimately, I think this question is kind of meaningless. (I think) the thermodynamic potentials of real gases are determined through experiments, and "parameter fitting", and not through "first principles" as we have done for the ideal monatomic gas.
The chemical potential determined by the Sackur-Tetrode equation might not be comparable to chemical potentials of real gases determined through experiments, since these quantities are (probably?) relative to some "standard zero" potential, whereas it's not clear what the chemical potential determined through the Sackur-Tetrode equation is relative to.
Also, Liouville's theorem is no longer applicable if total particle numbers (of some particles that evolve via Hamilton's equations) is not conserved, so correct Boltzmann counting is no less, or more, easier to justify than "incorrect Boltzmann counting". We would need another way to reason as to why the microstates we have chosen ought to be equiprobable.
As a side note, the goal of statistical mechanics (seems to be) to use probabilistic arguments to determine thermodynamic potentials of new systems, such that they interact "consistently" with the existing thermodynamic potentials of studied systems.
A cool observation.
As another side note, going back to the Gibbs paradox example, when we calculated the multiplicity, without correct Boltzmann counting, after the divider is removed, we could have done it in two ways, either $$ \Omega_\text{sys}' = \Omega(V_1+V_2, N_1 + N_2) \,. $$ as was done initially, or $$ \Omega_\text{sys}' = \Omega(V_1+V_2, N_1)\Omega(V_1+V_2, N_2) \,. $$ The two can be shown to be equivalent (again, not exactly equivalent since the second calculation does not consider the microstates where a small group of particles, a single particle say, contains all the energy of the system, and the others are very slow moving). The first interpretation says, the system after the divider is removed, is the same as a box of volume $V_1+V_2$ with $N_1+N_2$ particles. The second interpretation says, the system after the divider is removed, is the same as expanding the volume of the left and right boxes, to fill the size of both boxes, and the left and right boxes kind of "coexist".
The second interpretation is also how one would calculate the total system multiplicity for distinct gases that mix after the divider is removed. Without correct Boltzmann counting, the multiplicities of two mixed distinct gases, is the same as two mixed identical gases, and the multiplicity of two unmixed distinct gases, is lower than the multiplicity of two unmixed identical gases. This is opposite to correct Boltzmann counting. In some sense, this is more intuitive. Two mixed distinct gases is just as "useless" as two mixed identical gases, but useful work can be extracted from two unmixed distinct gases, so perhaps its entropy "should" be lower than two "unmixed/mixed" identical gases.
Sorry if this was too long, I just thought some parts might be interesting to others. I'm still learning the subject as well so I don't know if everything said is strictly correct, but I'm open to feedback.
This paper
Jaynes, E. T. (1996). "The Gibbs paradox".
by Jaynes was also kind of interesting as well. In one part he talks about how entropy is only defined up to an abitrary function of particle number $N$ in "phenomenological thermodynamics".
eugenhu
  • 555
10
There is no need for quantum mechanics. You can find a classical argument in Landau-Lifshitz, Statistical Physics, Chapter III, Paragraph 31.
What you have to understand is that when integrating over phase space, for example to calculate the free energy in the canonical ensemble, you should not integrate over all values of the canonical variables $p,q$, but only over the values which correspond to different physical states. Landau uses the notation $\int'$ to denote this; for example for the free energy you will have
$$\beta F = - \ln \int' e^{-\beta \mathcal H(p,q)} dp dq$$
where $\beta=1/k_B T$ as usual.
Now, it is often more practical to just integrate over the whole phase, i.e. to take $\int dp dq$ space instead that over the portions of phase space corresponding to different states, i.e. $\int' dp dq$. However, if you do so, you are overcounting the number of states. In the case of a gas of $N$ atoms, in order to get the correct counting, you have to divide the integral extended over the whole phase space by the number of possible permutations of $N$ atoms, which is $N!$. This is because if you switch the position of two identical atoms you are not getting a new physical state (this is the key point of the whole argument). To sum up, for a gas of $N$ identical atoms we have
$$\int ' \dots dp dq = \frac 1 {N!} \int \dots dp dq$$
which is Eq. 31.7 in my edition of Landau-Lifshits.
valerio
  • 16,751
This is a great question and both you and @valerio have given good answers. I will just add that, as suggested in the Jaynes paper you cite, the Gibbs paradox is really confusion about macrovariables and what constitutes a "subsystem". Entropy is only ever defined with respect to some set of macrovariables, so if you want to compare the total entropy with the entropy of the subsystems, you need to use the same macrovariables for the subsystems as for the complete system.
Specifically, if the particles are indistinguishable, $V_i$ is not a macrovariable. This is obviously true with the partition removed, since there is no way to tell from macro observations (that is, external interactions) which particles are in volume $i$. Less obviously, it is also true with the partition in place, since "indistinguishable" means there's still no way to tell from macro observations which particles are in volume $i$. The only macrovariable related to volume is the total volume, $V$.
Meanwhile, a meaningful way to divide the system into subsystems is to split it into $k$ groups of particles with $\{N_1,...,N_k\}$ particles in each group, where $N = \sum N_i$. (It's helpful to realize these particles need not be physically grouped - say, on one side of the box or the other. You could, for example, make a subsystem by counting off every third particle. Importantly, the subsystem is not identified with a volume of space, but with a set of particles.) Then by "extensive entropy", we mean that $S(N,V) = \sum S_i(N_i,V)$. That is, in this scheme you should think of the $i$th subsystem as occupying the entire volume $V$, as you indicated in your "cool observation". It doesn't matter if it happens that all the particles in a subsystem are grouped into a smaller volume like the left side or the right side or the upper right corner; such a fortuitous configuration is a particular microstate of the subsystem, for which entropy is not defined.
(As for $E$, we must choose the subsystems such that they are all in mutual thermodynamic equilibrium, so $E_i/N_i \approx E/N \,\forall\, i$. To say it another way, the correct macrovariable is not the energy but the temperature.)
Now the statement that the entropy is extensive can be written $ S(T,N,V) = \sum S_i(T,N_i,V) $, or $\Omega(T,N,V) = \prod \Omega_i(T,N_i,V)$. That is trivially true for an ideal gas of identical particles, however you count the states.
How does this change if the particles are distinguishable? Well, "distinguishable" means there is some macrovariable whose value depends on the states of the different types. If there is a mixture of xenon and neon atoms in the box, there is the possibility of introducing new macrovariables IF the setup includes some mechanism that reacts to xenon and neon differently, e.g. a partition that is permeable to neon but not to xenon. By inserting the partition, the relative fraction of xenon on the left and on the right are now available as macrovariables, since a difference in xenon concentration across the partition will produce a force on the partition. Furthermore, you could use the force to do work on the exterior or exert work on the system through the displacement of the partition, indicating that state differences involving changes in the new macrovariables are indeed associated with changes of entropy. You might quantify the new macrovariables as $N_{xl}/V_l$ and $N_{xr}/V_r$, or equivalently, $N_{xl}$, $V_l$, and $N_x$ (in addition to $V$, which is still a macrovariable.) So in terms of these macrovariables, $S = S(T,N,V,N_x,N_{xl},V_{xl})$ for the entire system AND for the subsystems.
pwf
  • 3,208
I too was put off by the appeal to quantum mechanics.
Let $\Omega(n,V,E)=\Omega_q(n,V)\Omega_p(n,E)$. I assume the factor $1/n!$ stems from $\Omega_q$, the configurational source of entropy.
I'm sure it is not always possible to factor $\Omega(n,V,E)$ as neatly as this. But, in some simple cases it is possible.
The number of ways of putting $n$ indistinguishable objects into $k$ boxes is $$ N_{k,n}={n+k-1\choose k-1}=\frac{\Gamma(k+n)}{n!\Gamma(k)}.$$ We can make $k$ really big, like $k>n^2/(2\varepsilon)$ and why not? We have point particles and space is infinitely divisible - continuous. If we make $k$ this large, then the fraction of configurations with boxes containing more than one particle is at most $\varepsilon$. Anyway, as $k\to\infty$ $$ \frac{\Gamma(n+k)}{n!\Gamma(k)}\sim \frac{k^n}{n!}$$ (Note the similarities with the birthday paradox). So increasingly (with ever larger $k$) we have boxes with either zero or one objects. So, for a finite volume $V$, some reference volume $V_0$, maybe $V_0=V/k$ and some $\lambda>0$, we could argue that we should have $$ \Omega_q(n,V)=\frac{\lambda^n}{n!}\left(\frac{V}{V_0}\right)^n.$$
In the continuum case it is even easier to avoid particles having the same birthday (location, cell, sub volume). So, this explanation is already too complex, I think. It is just some normalized volume to the n-th power, taking into account particle relabeling.
The divider argument: $\Omega(n,.)\star \Omega(m,.)=\Omega(n+m,.)$, along with $\Omega(n,V)=c(n)V^n$ is pretty compelling. Basically the convolution identity $\frac{1}{n!}Y(x)x^{n-1}\star \frac{1}{m!}Y(x)x^{m-1}=\frac{1}{(n+m)!}Y(x)x^{n+m-1}$, implying $c(n)=\lambda^n/n!$. (Some off by one errors here and there. Shouldn't matter that much)
awsnap
