A 10 meter graphene pulley with 10,000 teeth, attached to a second graphene pulley of 10mm with 10 teeth both in a low temperature vacuum chamber.
The first graphene pulley is being rotated by a powerful motor powered by nuclear energy. Rotating at 300,000 RPM. Wouldn't the second pulley rotate faster than the speed of light?
(2Pi * 10M /60s) *300,000RPM = 314,159m/s. Since it's attached to 10mm with 10 teeth. It means every one revolution of the first pulley, the second pulley would rotate 1,000 times. So, 314,159m/s * 1,000 = 314,159,265m/s.
Where is the impracticability in the above solution?
