When do we call something a particle, and when do we call something a wave? Do we call something a particle when it is highly localized? If that's right, then a wave packet is a particle. Do we call something a wave when it is not localized and when it shows interference pattern?
If a state is localized in position basis then it is called a particle (something that has a definite position) and if it is localized in the momentum basis then it is called a wave (something that has a definite wavelength, which, in Quantum Mechanics, relates to the momentum).
Having said that, I would add that in practice, any quantum state that is fairly distributed in the position basis is called a wave. It is not a strict definition. Moreover, it should also be noted that what we call the wave-function (i.e., the position basis representation of the quantum state) is not a wave in a mathematical sense, i.e., the equation according to which it evolves in time (the Schrödinger equation) is not a wave equation, it is a diffusion equation. So, to be honest, we simply mean a distributed or a little bit wiggly pattern when we say "wave" in the context of Quantum Mechanics. A more precise definition would be a distribution that has a specific wavelength (i.e., a specific momentum) as I mentioned, however, even such a wave-function wouldn't follow the wave-equation as it evolves, it would follow the Schrödinger equation (i.e., a diffusion equation).
Finally, all quantum states exhibit interference. However, you are correct in noticing that particle-like states wouldn't exhibit any distinctive interference-like behavior in the position basis. But, any wavefunction that has a distributed or a little bit wiggly pattern would exhibit noticeable interference, in particular, one doesn't need a distribution with a specific wavelength to exhibit interference.
yes
In quantum optics, photons are often represented as localized "wave packets". The "field theory" method of determining if something is a "particle" is if it obeys a particular commutation relation. Often times this leads concluding that in some interacting systems, so part of the system has this particular commutation relation and it's called a "quasi-particle". For example, the interaction between atomic dipoles and photons are labeled "polaritons" and are considered a type of "quasi-particles" because of their commutation behavior: $$\left[\hat{\Psi}_k,\hat{\Psi}^+_{k'}\right] =\delta_{k,k'}\left[\cos^2\theta +\sin^2\theta\frac{1}{N} \sum_j(\hat{\sigma}^j_{bb}+\hat{\sigma}^j_{cc}) \right].$$
Yes. Although this is the trickiest to answer. Wave are things that have multiple values distributed across space and follow some sort of differential-equation that looks like a wave. I'm careful not to say that "waves follow the wave equation" because quantum waves do not follow this (they follow something that behaves pretty "wave-like" resembling a complex version of the heat equation).
Electrical waves follow the wave equation (through a simplification of Maxwell's equations).
Classical particles (in some materials, like water or air, for example) are held-together with a particular force (a harmonic oscillator usually) and can be shown to follow each other in a way that follows the wave equation.
Quantum waves follow Schrödinger's equation.
Photons follow both the wave equation and Schrödinger's equation.
