Is a Lagrangian unique in the same field? Is Hamiltonian unique?
If it is unique then please explain why is it so and if it is not then please explain why is it not so.
The system is described by the Euler-Lagrange equations. So basically the Lagrangian is the description of the system. However the Euler-Lagrange equations can be the same for different Lagrangians. The field will be the solution of the Euler-Lagrange equations. They are differential equations so the boundary conditions can change the solution.
Now you can go from a Lagrangian description to a Hamiltonian via Laplace transform which is an one to one process.
jmstf94
  • 63
