In my classical mechanics class they asked why the kinetic energy for a holonomic mechanical system has a quadratic form. Of course for a autonomous standard system (system that is holonomic and the constraint do no virtual work) you can just calculate that $$ T = \frac { 1 } { 2 } \sum _ { i = 1 } ^ { M } m _ { i } \left( v _ { i } \cdot v _ { i } \right) = \sum _ { j = 1 } ^ { n } \sum _ { k = 1 } ^ { n } a _ { j k } ( q ) \dot { q } _ { j } \dot { q } _ { k } $$ with $$ a _ { j k } ( \boldsymbol { q } ) = \frac { 1 } { 2 } \sum _ { i = 1 } ^ { N } m _ { i } \left( \frac { \partial \boldsymbol { r } _ { i } } { \partial q _ { j } } \cdot \frac { \partial r _ { i } } { \partial q _ { k } } \right). $$ So you can write $$ T = \dot { q } ^ { T } \cdot A \cdot \dot { q }. $$ But what is the physical reason?
Asked
Active
Viewed 174 times
That the kinetic term $T(q,\dot{q},t)$ is a second-order polynomial in the generalized velocities $\dot{q}$ can be viewed as:
a consequence of
that the constraints are holonomic, so that the positions ${\bf r}_i(q,t)$ do not depend on the generalized velocities $\dot{q}$,
and that the non-relativistic kinetic energy is $T=\sum_{i=1}^N\frac{m_i}{2}\dot{\bf r}_i^2$,
as OP already suggested.
merely an ansatz or approximation, partially justified by the fact that the kinetic term should be bounded from below. (This ansatz is famously violated for relativistic point particles.)
References:
- H. Goldstein, Classical Mechanics, Section 1.6.
