In my understanding, not only mass but any kind of energy/ force bends spacetime. So is it correct to say that every object in the world moves along geodesic? If the object is submit to a force, it will not feel an acceleration: the force will bend the underlying spacetime --> the geodesic of the object will change --> its worldline in spacetime will change, but only because the curvature of spacetime has changed. It will still move along a geodesic. So acceleration, in some sense, simply doesn't exist anymore.
Is this interpretation correct?
Not every force is manifested through the curvature of spacetime, only gravity. Take the electromagnetic field, for example. It has energy-momentum density, so it affects the gravitational field and hence the movement of particles. But this is not the only effect it has: on a charged particle, it also acts directly through the electromagnetic force.
Mathematically, for a particle of mass $m$ and charge $q$ in an EM field $F_{\mu\nu}$, the geodesic equation is modified to
$$\frac{d u^\mu}{d\tau} + \Gamma^\mu{}_{\nu\lambda} u^\nu u^\lambda = \frac{q}{m} F^\mu{}_\nu u^\nu.$$
If there was no electromagnetic field, the right hand side would be zero, and you would just have the geodesic equation with the gravitational field $\Gamma^\mu{}_{\nu\lambda}$. If there is an EM field, then two things happen. For one, its energy-momentum influences the gravitational field, so that $\Gamma^\mu{}_{\nu\lambda}$ changes. But it also directly applies a force on the particle, given by the right hand side of the equation, and this effect is usually much bigger. The particle doesn't follow a geodesic anymore.
Javier
  • 28,811
