What is the reason 1/4 coefficient in the tensor multiplication of the electromagnetic field strength? $$\mathscr{L} = -\, \frac{1}{4} \, F_{\mu \nu} \, F^{\mu \nu}. \tag{1}$$
Asked
Active
Viewed 231 times
It's a convention, to simplify some calculations. You could add an arbitrary factor. In SI units for example: $$\mathscr{L}_{\text{EM}} = -\: \frac{1}{4 \mu_0} \, F_{\mu \nu} \, F^{\mu \nu}. \tag{1}$$ However, to recover the non-homogeneous Maxwell equation: $\partial_{\mu} \, F^{\mu \nu} = \mu_0 \, J^{\nu}$, you need the $-\, \frac{1}{4}$ factor.
Also, you could write the following: $$-\: \frac{1}{4} \, F_{\mu \nu} \, F^{\mu \nu} = \frac{1}{2} (\, E^2 - B^2), \tag{2}$$ which is similar to the classical mechanical expression $L = K - U = \frac{1}{2} \, m v^2 - U$.
Cham
- 8,015
