I'm curious about part of the derivation of the wave equation as is done in all references that I've seen so far (I'm gonna reproduce only the part that's puzzling me).
We apply Newton's second law to the motion of a piece of vibrating string in the vertical direction. Let's call the vertical direction $y$, and the horizontal direction $x$. Then we limit ourselves to an infinitesimal part of the string, and we write down the mass of this piece as $\rho \Delta x $. The fact that we could replace the length of this portion of the string $l$ with $\Delta x$ is because we assumed small oscillations: $l\approx \sqrt{(\Delta x)^2+(\Delta y)^2}\approx \Delta x$, as the displacement of string from the equilibrium position $\Delta y$ was assumed to be very small.
Now the equation $\partial^2y/\partial t^2=c (\partial^2y/\partial x^2)$ is derived after some more calculations ($c$ is just some constant). This equation is derived based on the assumption that the oscillation is small ($\Delta y\approx 0$) but it's obviously satisfied for non small oscillations (e.g. sine and cosine type of waves) as well.
So how does the proof generalize to the case of non-small oscillations? In other words, why does a string oscillation which is not necessarily small, satisfies the wave equation as well?
